Primary fan relay
Old Aug 14, 2012 | 07:13 PM
VRSCDX's Avatar
VRSCDX
Default Primary fan relay
I don't have my FSM yet so was wanting to know where the primary cooling can relay is on a 96 LT4??? Any help is appreciated!!!
Old Aug 14, 2012 | 07:49 PM
tpfarm's Avatar
tpfarm
I am assuming tht it is in the same place as other later C4's and that is on the side of the driver side radiator area, it's the one towards the front of the car.
Old Aug 14, 2012 | 11:26 PM
pcolt94's Avatar
pcolt94
There is not 1 "primary cooling can relay" on the 96. There are 3 relays that work together that will set the 2 fans on either low or high speed. It is controlled by an output from the PCM, one output signal per each relay, or 3 outputs from the PCM to control the fan speeds.
To Primary fan relay
