Starter Issue
Old Aug 17, 2012 | 08:26 PM
TheMonge23's Avatar
TheMonge23
Default Starter Issue
96 LT4 6-speed won't start. I have known good battery (just put in a new one) but when I turn the key to START I can hear what I assume is the starter motor spinning but there is no cranking. The noise stops as soon as I pull the key back from START.
Could it be anything other than a bad starter?
Old Aug 18, 2012 | 01:10 AM
1986coupe's Avatar
1986coupe
Check the electrical connections at the starter and solenoid. If there is a poor connection then it will not turn over properly.
Old Aug 18, 2012 | 03:49 AM
tahoemedic's Avatar
tahoemedic
If the solenoid is bad, the starter will turn but not engage the flywheel. Sounds like it may be time for a new starter or you can try to replace the solenoid itself.
Old Aug 18, 2012 | 02:14 PM
hitmanpty's Avatar
hitmanpty
I had starter problem for a long time. I try everything. even rebuild the hold thing. at the end my starter never work properly. what I did was get new starter. and my problem was solve.
If I had do tyhat from the begining . I will had save a lot of time and money
To Starter Issue
