Code 64 on my 93 C4???
Old May 31, 2002 | 05:22 AM
vette&fun's Avatar
vette&fun
Default Code 64 on my 93 C4???
Could it be the Oxygen sensor or just the fuel pressure set too high? I set my fuel pressure to 48 psi. Check engine light often turns on during the afternoon. During the morning, even if I drive for an hour, it's still fine. I can feel the power is loosing when the check engine light turns on. Also, it usually turns on when I try to hit hard on the pedal and doing over or around 100mph. Got code 64. Any idea? Does the Accel 300+ ignition have anything to do with this problem?
