Ignition Coil Grounding Strap
Old Aug 27, 2012 | 06:26 PM
raiderz's Avatar
raiderz
Default **UPDATE**Ignition Coil Grounding Strap
1986 Coupe L98 Stock...A.I.R. and EGR Deleted.... H.E.I. Distributor
My car is in the shop trying to figure out a sputtering.. extended sitting / cold start issue.
Mechanic called today and said he has figured it out. newer H.E.I. coil that was installed a few months ago is sparking in the cap. He says the metal grounding strap is missing?...i told him there was never one there even before we changed the coil.
The new coil same as the old coil has a black ground wire...but no secondary ground strap??
Is he correct???
I understood the major grounding for this takes place on the block near the oil filter.
Would like to hear your thoughts on this
Ray
Old Aug 27, 2012 | 06:38 PM
oldalaskaman's Avatar
oldalaskaman
did you attach it to one of the screws that hold the coil, if so , its grounded, if you're not grounding thru that , either you have the wrong coil, you need to clean the ground, or, you need the grounding thingy
hope this helps
Old Aug 27, 2012 | 07:01 PM
383vett's Avatar
383vett
As I recall, there are two coils available for the in cap hei. The color of wire has something to do with it. I have run an external coil since day 1 so I can't help anymore than this.
Old Aug 27, 2012 | 07:20 PM
oldalaskaman
usually the earlier one had the ground that was attached to a metal strap tat was bent so it fit thru the plug , and that got a plug from the harness that went to a ground. then they started grounding thru one of the front coil hold down screws, either way works
LongBeachC4's Avatar
LongBeachC4
The strap is a bent metal piece the runs from the coil mounting hole to the center rear terminal on the side of the cap. If you change the coil, you have to remove and replace the strap. There are 3 wires that plug into the side of the cap, brown, white and black. The grounding strap has a terminal that connects to the black wire.
Old Aug 27, 2012 | 07:24 PM
Joe C's Avatar
Joe C
you should have one of these configurations - either a metal strap (that is the center pin, or tab of the connector), or a black wire attached to the center pin or tab. both the strap or wire tab connects to the outer ring of the coil plus the black wire of the coil, thus ground. the all metal , one piece ground strap replaces the ground wire on many model coils -
not sure if i'm making this clear or not. hope this helps...
Old Aug 27, 2012 | 07:30 PM
raiderz's Avatar
raiderz
This is the coil i have. It is identical to the coil i replaced.
Red / White with black ground wire that is securely connected to left hand front bolt hole in coil housing.
There was no other L or S Shaped steel grounding strap when i first did the swap.
Old Aug 27, 2012 | 07:41 PM
Joe C's Avatar
Joe C
you still need a center pin (on the connector) attached to the outer ring of the coil. i have to agree with your mechanic - the strap, whether a wire or a solid metal piece is missing and needs to be there. now what impact a missing ground would have on the engines performance, i don't know - never ran across that senerio...
Old Aug 27, 2012 | 07:44 PM
oldalaskaman
you have the later version, and it doesnt work, may need to clean the metal areas. if you look at the plugs that connect to your dist, and you dont have a wire that would go to that strap, you dont need it.
Old Aug 27, 2012 | 07:47 PM
Joe C's Avatar
Joe C
, although i'm not aware of a later version. best thing is to check how many wires are on the connector that plugs into the distributor - 2 or 3 - ???
Old Aug 27, 2012 | 08:25 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The black wire with ring eye is the secondary ground that is attached with coil mounting screw. There are no other ground straps.
Old Aug 27, 2012 | 08:49 PM
AGENT 86's Avatar
AGENT 86
You say the coils are identical, including the red and white ?
Old Aug 27, 2012 | 09:03 PM
WW7's Avatar
WW7
Actually there is another ground strap,(last pic down) it goes from the black ground wire on the pin, to the harness where the red and white wires connect...The black wire is suppose to hook to the pin on the coil, so when its put together the wire will connect with the little metel bracket to ground it to the harness that the red and white wires hook to........WW
Deepa's Avatar
Deepa
WW, just went through this, and that is exactly how I set mine up. Do you have the ground wire with the eyelet screwed into the same location that the strap is set up under the coil??? I am not sure If I have it under the same screw location as where I attached the ground wire.
EDIT:: WW just read your last post, and I am going to make sure the eyelet is connected to correct bolt...
FWIW...installed a new coil 2 yrs ago, and there was not a grounding strap (metal one, not the black wire with the eyelet connector), so I did not install the strap with the new coil.
The coil laster two years and was cooked to all hell when it went. It was very loose on the metal square and there was black powder everywhere. The new coil indeed does have the strap hooked up.
Old Aug 27, 2012 | 09:13 PM
WW7's Avatar
WW7
Its not really necessary to have the black wire touching the metel gounding strap, once you connect the black wire to the pin the whole perameter is grounded so just having the metel strap touching it will ground it.If you look at mine the black wire is actually on the opposite side from where the metel ground strap is and it worked fine.
Old Aug 27, 2012 | 09:15 PM
raiderz's Avatar
raiderz
Yes the coils i have both old and new are identical to the coil in the picture i posted
It looks like i am missing the hooked ground strap that is suppose to sit under the coil...i only have the black wire with the eyelet hooked up right now...guess the mechanic is right??
I might have lost that little strap when i swapped in the new coil a few months ago?? i dont know. He is picking up a new cap and coil along with the hooked ground strap, so we will see how that works out.
Im surprised it didn;t burn up sooner if this strap is so important?
Ray
Old Aug 27, 2012 | 09:21 PM
Deepa's Avatar
Deepa
Mine lasted two years without the strap...I do not know how long yours had been that way, but symptoms started with a high rmp hesitation/stutter...then it all went downhill within a few weeks.
To Ignition Coil Grounding Strap
Old Aug 27, 2012 | 09:22 PM
WW7's Avatar
WW7
Ray
If you look at Joe Cs pics above you will see there are 2 types of coil hookups..The one with just 2 wires (red and white)needs the grounding strap...The one with a black 3rd wire that goes into the slot with the red and white wire ,doesn't need the grounding strap...WW
Old Aug 27, 2012 | 09:51 PM
Deepa's Avatar
Deepa
Are you sure??? The instructions that came with my coil (3 wires, red, black, white) insisted that install the strap no matter what.
Old Aug 27, 2012 | 09:52 PM
AGENT 86's Avatar
AGENT 86
My bad, I was at the beach surfing on my phone and not recalling another wire coming from coil. Looked at the FSM on my iphone and confirmed only 3 wires coming from coil.
It's been years from my last cap change and forgot about that strap in cap.
