1993 Vet running problems
Old Aug 30, 2012 | 04:39 PM
mowerdoctor's Avatar
mowerdoctor
3rd Gear
Default 1993 Vet running problems
Can anyone tell me what to look for. Yesterday my car ran great, last night I tried to start it and it stumbled as if it was flowed and running on 7 cylinders, this morning I tried it again, It starts if I hold the gas pedal to the floor than it stalls or to get it to stay running I have to keep pumping the gas pedal. I have not washed or got water on the engine and 700 miles ago the distributer assy was replaced. I have no trouble codes to go by. Oil pressure is good. 70K miles and used like a Sunday driver. 6sp.code P and Y.
Has this happened to anyone.
Thanks ahead of time.
Old Aug 30, 2012 | 10:35 PM
1986coupe's Avatar
1986coupe
Check fuel pressure. How is your fuel filter? Air filter?
Sometimes on LT1s the coil and/or ICM can cause running issues because of the heat that they are subjected to.
Old Sep 1, 2012 | 01:59 AM
mowerdoctor
3rd Gear
I checked the MAP sensor today, the readings were good, I checked with my Mighty Vac pump. I hooked up my OTC Genisys and started after holding my gas peddle down, the more vacuum I put on the MAP sensor the better it Idled, I went through my reader and noticed that the coolant temp was -23 but my temp gauge in the car was getting hot and the rad fan wasn't going on. I shut the engine off than turned the key back on so my scanned was reading the computer, I jumped out the temp sensor on the front of the engine, the scanner than read 304 degrees, I started up the engine and it ran perfect.
My next step is to replace the computer temp sensor and the MAP to be safe.
Thanks for your suggestions
Chris
To 1993 Vet running problems
