Headlight Adjustment ?
Old May 31, 2002 | 04:27 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Headlight sags a little. How to adjust?
My passenger side headlight sags just a little bit below the hood. How do you adjust it??
[Modified by FlyboyZR1, 2:47 PM 5/31/2002]
Old Jun 1, 2002 | 04:26 AM
RichAshley-Black99's Avatar
RichAshley-Black99
Default Re: Headlight sags a little. How to adjust? (FlyboyZR1)
Im glad you asked that I need to adjust one of mine and have no idea how to do it. :smash:
Old Jun 1, 2002 | 12:35 PM
FlyboyZR1's Avatar
FlyboyZR1
:D ttt :D
Old Jun 1, 2002 | 02:48 PM
Louis J Hoppmann's Avatar
Louis J Hoppmann
I was wondering about this myself. I just finished adjusting the right side it took about 30 min. First turn the **** that opens the lamp until it is about 1/3 open. Then take the 4 screws that hold the cover that you see when the lights are on out. The two at the bottom are Philips, put your finger up in behind the clip that the screw goes into because they might be loose. Then take the two-torx screws out of the other end. This would be a good time to clean and polish this part. Now turn the **** to close the light. There are four 10mm nuts that hold the cover on, loosen them all. Now you can move the cover up or down to get a flush fix. Tighten them back up slowly because the cover will move as they are tightened. You need to put the hood down and look at it before you put the other cover back on. When you are satisfied with the fit put the lamp cover back on. Hope This Helps Louie
To Headlight Adjustment ?
