1988 abs
Old Sep 9, 2012 | 05:42 PM
dsmithh's Avatar
dsmithh
Default 1988 abs
The ABS lamp on my 88 has been on more than off lately. I wonder what the first step in troubleshooting should be?
Old Sep 10, 2012 | 06:13 PM
Steve59's Avatar
Steve59
Check the wheel senors. They get dirty and may need to be cleaned. Don't break them.
Old Sep 10, 2012 | 08:34 PM
yd328's Avatar
yd328
I would try to get the trouble code if you have access to a scan tool. You can also check some of the basics first, brake pads, fluid level, any leaks, and fuses.
Gary
Old Sep 10, 2012 | 11:06 PM
leesvet's Avatar
leesvet
Good luck with the early Bosch scan tool...that was an "off-board" diagnostic tool and was d/c by GM right about that time. Later models had ABS incorportaed into the system, so there was only one scanner for everything instead of a special scanner for abs only,.
Often a intermittent abs lite means you have a wheel bearing going south,. as the bearing gets loose the tolerance for the sensor changes and triggers the lite. Grease and dirt on the sensors also cause it.
Get ABS parts for that yr and earlier from FleaBay. Some of the big ticket items like modules can be bought from the catalog stores. Sensors..lines, used only. Older Mercedes use the same system and so did Caddys. Someone said that Porche did too.
To 1988 abs
