camshaft for l98
Old Sep 17, 2012 | 09:42 PM
76z28's Avatar
76z28
Default camshaft for l98
I am looking for a camshaft that isnt ULTRA expensive, i found an edelbrock cam http://www.summitracing.com/parts/EDL-2209/ that i was hoping works with stock heads
I know the crank 2032 cam works but man is that sucker expensive, also would an LT1 cam be an upgrade for a 383 with stock runners? If so where can i find a new one?
I was hoping for a cam in the 220 duration area with about .450 lift but i cant find a roller cam with those specs
Any other cam opinions would be great!
heads only have a valve job, stock springs
manifolds with catless exhaust
and 383 kit are the upgrades for now
My stock cam is unusable or else i would throw it back in with 1.6 rockers
thanks!
Old Sep 17, 2012 | 09:45 PM
cv67's Avatar
cv67
St. Jude Donor '05
Flat tappet cam?
Keeping the stock heads?
Intake manifold?
Old Sep 17, 2012 | 10:01 PM
76z28's Avatar
76z28
Flat tappet cam?
Intake manifold?
It's a 1000 corvette so it's roller
Stock heads and intake
Old Sep 17, 2012 | 10:04 PM
76z28's Avatar
76z28
1990 corvette not 1000
Calderone's Avatar
Calderone
Some numbers i got for you , hope this is useful for you at least for compare
ZZ4 cam :
Duration @.050 208/221
Lift: .474/.510
112 LSA
1500-5500 rpm range
Hotcam
Duration @ .050", 218/228
Lift: .525/.525 ,
112 LSA
Stock LT1
202@ .450/
207 @ .450 (1.5RR)--- 117 LSA
Cam specs
Cam----INT / EXT
Stock LT1---202@ .450/ 207 @ .450 (1.5RR)--- 117 LSA
Stock LT4--- 203@ .476/ 210@ .480 (1.6RR)--- 115 LSA
GM Performance Parts
LT4 Hot Cam --- 218@ .525/ 228@ .525 (1.6RR)--- 112 LSA --- 1800-5800 RPM
GM12370847 --- 234@ .539/ 242@ .558 (1.5RR)--- 112 LSA --- 2000-6800
GM12730846 --- 220@ .509/ 230@ .528 (1.5RR)--- 112 LSA --- 1800-5800
Comp Cams
CCA-07-304 --- 210@ .500/ 220@ .510 (1.5RR)--- 114 LSA --- 1000-5000 RPM
CCA-07-305 --- 220@ .510/ 230@ .510 (1.5RR)--- 114 LSA --- 1500-5500
CCA-07-306 --- 230@ .510/ 244@ .540 (1.5RR)--- 112 LSA --- 1800-5800
CCA-07-500 --- 206@ .480/ 212@ .488 (1.5RR)--- 112 LSA --- 1000-5000
CCA-07-501 --- 212@ .488/ 218@ .495 (1.5RR)--- 112 LSA --- 1200-5200
CCA-07-502 --- 218@ .495/ 224@ .503 (1.5RR)--- 112 LSA --- 1500-5500
CCA-07-503 --- 224@ .503/ 230@ .510 (1.5RR)--- 112 LSA --- 1800-5800
CCA-07-464 --- 202@ .550/ 212@ .546 (1.5RR)--- 113 LSA --- 1000-5000
CCA-07-465 --- 210@ .560/ 218@ .550 (1.5RR)--- 113 LSA --- 1200-5200
CCA-07-466 --- 218@ .570/ 224@ .565 (1.5RR)--- 113 LSA --- 1800-5800
CCA-07-467 --- 230@ .576/ 236@ .570 (1.5RR)--- 113 LSA --- 2000-6000
CCA-07-468 --- 242@ .584/ 248@ .579 (1.5RR)--- 113 LSA --- 2200-6200
Crane Cams
CRN-104227 --- 210@ .479/ 224@ .518 (1.5RR)--- 112 LSA --- 2000-6000 RPM
CRN-104228 --- 210@ .479/ 224@ .518 (1.5RR)--- 112 LSA --- 2000-6000
CRN-104241 --- 218@ .498/ 218@ .498 (1.5RR)--- 116 LSA --- 2800-6500
CRN-1449555 --- 210@ .531/ 218@ .531 (1.5RR)--- 114 LSA --- 1900-5600
CRN-1449571 --- 210@ .531/ 218@ .531 (1.5RR)--- 112 LSA --- 1000-5800
CRN-1449561 --- 216@ .551/ 224@ .551 (1.5RR)--- 115 LSA --- 1500-6000
CRN-1449581 --- 220@ .551/ 220@ .551 (1.5RR)--- 112 LSA --- 3000-6500
CRN-1449591 --- 224@ .551/ 224@ .551 (1.5RR)--- 114 LSA --- 3000-6500
CRN-1449601 --- 228@ .600/ 232@ .600 (1.5RR)--- 112 LSA --- 3500-6500
Edelbrock
EDL-2108 --- 218@ .525/ 218@ .525 (1.5RR)--- 112 LSA --- 1500-5500 RPM
Lunati
LUN-54778LUN --- 206@ .469/ 215@ .489 (1.5RR)--- 112 LSA --- 1200-4500 RPM
Accel
ACC-74220 --- 215@ .499/ 220@ .510 (1.5RR)--- 114 LSA --- 1200-5800 RPM
ACC-74211 --- 211@ .499/ 219@ .525 (1.5RR)--- 112 LSA --- 1000-5800
ACC-74219 --- 219@ .525/ 219@ .525 (1.5RR)--- 112 LSA --- 1200-6200
Old Sep 17, 2012 | 10:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
A 1000 huh
If you arent going to upgrade heads youll need to hang the valve open longer to get the air in/out lift under 500.
It has to smog Ca also?
Old Sep 17, 2012 | 10:11 PM
76z28's Avatar
76z28
ZZ4 cam :
Lift: .474/.510
112 LSA
1500-5500 rpm range
Hotcam
Lift: .525/.525 ,
112 LSA
Stock LT1
202@ .450/
Cam specs
Cam----INT / EXT
Comp Cams
Crane Cams
Edelbrock
Lunati
Accel
I'll be looking at the comp
CCA-07-502
Looks like it should be where I want
I'm trying to stay under .510 lift be ause of valve guide issues with the heads. If its around 299 I can buy springs to go with it over the crane cam I chose
As for year being a 1000 > yes this thing is ancient! Haha but yeah this thing has to pass smog and I'm going to try and find something similar to the 2032 because it is smog legal
Old Sep 17, 2012 | 10:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
Keep the duration under 220 (in the 2teens somewhere) wide lobe separation and lift under say 500 youll be fine. Get a good tune on the ecm. Actually more to it than that to selecting but in general..you can jump 8-10 deg larger in duration than the 350 and be Ok most times.
Old Sep 18, 2012 | 01:39 PM
ch@0s's Avatar
ch@0s
What ever you do don't get a cam from Ebay. I got one from an Ebay member that sells LT$ hot cam and CC502 knockoffs and ended up with a paperweight for a motor.... willhoites cams
Old Sep 18, 2012 | 04:05 PM
bjankuski's Avatar
bjankuski
Use the hotcam with 1.5 rockers.
Done, Hyd roller .492 lift 218/228 @50 on a 112 LCA and cheap.
Old Sep 18, 2012 | 04:42 PM
rklessdriver's Avatar
rklessdriver
Stock L98 Valve springs won't run that....
IMO Without changing the valve springs he should stick to running the stock cam...
Instead he wants to change it over to flat tappet?? WTF
The reason you can't find a roller in the 220@.050 and under .450 lift is because that cam would really SUCK performance wise.
Your best option is the GM Hot Cam PN 24502586 $205
http://sdparts.com/details/gm-perfor...parts/24502586
There is no reason to pull the entire top end and front of the motor apart and then NOT to buy a $35 set of LT4 valve springs.
http://sdparts.com/details/gm-perfor...parts/12495494
A second cam option would be the ZZ4 cam, PN 10185071 $212
http://sdparts.com/details/gm-perfor...parts/10185071
But your still gonna need the LT4 springs to run it and IMO the Hot cam would out run it.
Will
Old Sep 18, 2012 | 04:56 PM
76z28's Avatar
76z28
Will
Never want a flat tappet lol I have seen what those do when they go flat but that is exactly what I was looking for!! I am going with the hot cam and a set of springs
Thanks!!
To camshaft for l98
