hey, the 1/4 mile is closed for the season where i am and i was just wondering if you guys could give me an estimate of what my l98 c4 would run. the mods are tb bypass, airfoil, gutted exhaust, ram air intake through license plate, 12* advanced timing and 3.07s in the rear, thanks
think id do alright against a lt1 camaro with full exhaust?
NO.
I'm going to go ahead and say you'll be luck to break into the 14's on your first pass. Your CAR might go low 14's...but how much drag track experience do YOU have? I'm guessing not much by your post. Could be wrong though.
There won't be much to mess with you on the street unless its a newer corvette... Trust me! Even these newer camaros are surprised what a c4 is capable of
To be honest I was! Lol
I'm hoping for low 13s or high 12s with my changes
Different running it at the track than the street
Start going to the track and youll lose the urge to street race...and probably live longer.
As said your first pass could be a 15. Once you learn how to get the car to leave at that track that night (conditions will be a little different ea time) then you can judge what does what. Ill say 14 something best.
Leave it in D (not OD) and just give the tires a quick clean off if anything.
Stay OUT of the burnout box if on street tires, leave on the last yellow.
My 87 C4 runs high 12's only because I have Willie's (383 Vette) old Good Year Eagles and Gotti rims on it and it is 100% California emissions legal...
thanks for the info, think id do alright against a lt1 camaro with full exhaust?
It should be close. The trouble you may experience is launch. Between tire spin, and the independent rear suspension. The Camaro may hook up a little quicker, but then there are a ton of variables in this scenario, so who knows. Both cars have about the same in terms of power. If their auto's they're running the same trans essentially. You probably have quicker rear end gears, so once you hook up, you'll get the jump on the bottom, but the LT1 breathes a little better so he'll probably have you at the top. The Camaro has a rear suspension that is more suited to drag racing however.
You said you're 16? You have quite a ride for that age, congrats. A little bit of advice...find a safe place to practice some launches. The rear end of these things can slide out on you, and when they do, they do it in a hurry. If you're not experienced with it, really bad things can happen. Really bad things. My first run in my LT4 on a drag strip saw me completely sideways shortly after launch. Fortunately, I had enough experience to get out of it safely. Just remember that surviving is more important than winning.
