LT4 info needed
Old Jun 3, 2002 | 01:14 PM
snaketr's Avatar
snaketr
Default LT4 info needed
Does anyone know or may have information on installing a LT4 intake in an L98 engine. What I am looking for is how they drilled and machined for the distributor. I have seen this topic on here with pics of a intake that was done and I need to see the pics again or some technical info on it.
Old Jun 3, 2002 | 01:20 PM
Arisa's Avatar
Arisa
Default Re: LT4 info needed (snaketr)
There is a web page somewhere explaining how to do it. I know the guy had to make a special washer to fit between the dist. & the intake. The intake alone is too low where the dist. hole goes. I'll see if I have it bookmarked somewhere in my mess I call Explorer.
Neal
Old Jun 13, 2002 | 06:36 PM
cnc LT4's Avatar
cnc LT4
7th Gear
lt4's heads are raised runner. The intake runners on the lt4 intake would not match up to your L98 heads intake runners. An lt1 intake however may work if you work out the dist. clearance...never really thought about it.
Old Jun 13, 2002 | 06:45 PM
James94LT1's Avatar
James94LT1
Default Re: LT4 info needed (cnc LT4)
http://www.lt1intake.com
[Modified by James94LT1, 10:47 PM 6/13/2002]
To LT4 info needed
