Need help on superram bracket
Old Oct 6, 2012 | 01:46 PM
Matatk's Avatar
Matatk
Default Need help on superram bracket
Same post I made on CG...hoping to get some more guys here who have a SR installed:
So I'm getting close on finishing up the SR install. Went to put on the accelerator cable, cruise cable, and tv cable. I had a lot of trouble with the tv cable, it seemed to bind up under the plenum not allowing for proper adjustment. I could barely bolt the bracket on and I was afraid the extra tension would damage the tv cable mount.
I am using the bracket the PO provided. It was slightly different than mine, so I figured it's the accel 74200 that is supposed to be used. Now upon closer inspection, I think the slight differences are just because it was from a Camaro of a different year.
So I measured the angle of the stock bracket and it's approximately 145*. I am debating whether or not to try to find the correct bracket or mod the extra one I have. Can someone measure their SR bracket angle so I can get the correct measurements? Any help is appreciated.
Matthew
Old Oct 6, 2012 | 02:50 PM
cumbercr's Avatar
cumbercr
Do you have the original stock bracket? That's what I'm using. I also received a bracket when I purchased the SR. I came to the conclusion it was from a Camaro. Just like you found, it did not work.
Old Oct 6, 2012 | 03:33 PM
Matatk's Avatar
Matatk
I have the stock bracket. The 89 corvette bracket and 92 camaro bracket are identical in terms of the angle of the cables/mounting points. Only a very slight difference in the machining of the brackets and one extra "triangle" tab in the hole for the cruise cable on the camaro bracket.
If I can't find the SR bracket I have no problem cutting the camaro bracket and fixing the angle. I just want to know what it is.
Matthew
Old Oct 6, 2012 | 05:00 PM
cumbercr's Avatar
cumbercr
Matthew
How are you measuring the angle?
Old Oct 6, 2012 | 07:48 PM
cshuman's Avatar
cshuman
Here is a picture of mine if this helps
Old Oct 6, 2012 | 08:54 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
I have one... Just need to look for it... Bought it from Jeggs or Summit
Old Oct 6, 2012 | 09:21 PM
Calderone's Avatar
Calderone
Stock bracket here too !
Summit does not carry it anymore
Accel part number is 74200
Old Oct 7, 2012 | 01:11 AM
Matatk's Avatar
Matatk
Very clear picture, thanks. I think tomorrow I will put a protractor up to the computer screen and check the angle....no joke. What I need to know is that interior angle and that's a perfect shot!
Thanks again,
Matthew
Old Oct 7, 2012 | 01:14 AM
Matatk's Avatar
Matatk
If you aren't using it and are interested in selling it, please let me know....thanks.
Matthew
Old Oct 7, 2012 | 10:35 PM
Matatk's Avatar
Matatk
Thanks again to Chuck for the photo. Here's a crude photoshop comparison I did for future reference:
http://www.corvetteguruforum.com/mod...orumpost208282
To Need help on superram bracket
