Zf 6 speed help
Old Oct 9, 2012 | 01:21 PM
parriedog49's Avatar
parriedog49
Default Zf 6 speed help
Getting oil film on face of flywheel, i pulled flywheel, its not coming from rear main seal, it looks to be coming from input shaft of trans, does the zf have a seal for the input shaft, i cant seem to find any pictures on the net
Old Oct 9, 2012 | 02:01 PM
WVZR-1's Avatar
WVZR-1
It has a seal and also an o-ring to seal the guide-tube to the retainer. Both should be pretty easy to source locally if you're doing it yourself. I'd first check the "vent tube" and make sure it's clear!!
O-ring is a 53 X 2 I believe and the seal is a 35 X 50 X 7 - these you could do local BUT there's a gasket required also and that is substantially more difficult to come by. Here's a thread that might be a good read:
http://forums.corvetteforum.com/c4-t...any-ideas.html
Old Oct 9, 2012 | 05:11 PM
96GS#007's Avatar
96GS#007
Check your clutch fluid level. Wouldn't be surprised if the slave cylinder is leaking....which results in fluid all over the flywheel.
Old Oct 9, 2012 | 11:08 PM
mtwoolford's Avatar
mtwoolford
contact Bill at ZFDoc for things ZF related
Old Oct 13, 2012 | 01:38 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
WVZR1 is correct.
On my 94, the Previous owners had +/- 3 clutch replacements due to mis-diagnosis of rear main when it was the tranny input shaft seals.
Two other things to also check.
1. if LT1 - check Oil pressure switch/fuel cut-off connection at back of intake manifold -- leak there can get to clutch.
2. Tranny vent hose -- should be at/near firewall and have a filter on it -- make sure not pinched as would cause tranny build-up of pressure which will exit easiest way --- front seals.
Old Oct 15, 2012 | 09:05 PM
chrldo's Avatar
chrldo
dont know what year your car is , theres a service bulletin #92-304-6A for 1992 5.7 engines. Flint built engines with the letter "V" as the first digit of the engine serial number have an oil leak at the camshaft plug commonly misdiagnosed as a rear main seal leak.
Old Oct 17, 2012 | 03:23 AM
dizwiz24's Avatar
dizwiz24
This was the source of amber drops of fluid at the bottom of the bellhousing on mine.
I thought it was rear main seal (big job), but was luckily just clutch slave cylinder
To Zf 6 speed help
