Rattling Noise
Old Jun 5, 2002 | 03:44 PM
WHRITZY's Avatar
WHRITZY
Default Rattling Noise
When I first got my 90, you could hear what sounded like rocks or marbles in an empty coffee can when you turned off the ignition...just rattled for a second and quit. The car had 23k on it at that time. I figured it was a pre cat or main cat problem and didn't worry about it too much because I knew the mods I was contemplating would solve the situation.
Welll.......my new mods (not yet posted in my signature) include headers (thereby eliminating pre cats) and a new Random Tech High Flow Main Cat...the sound is still there when I turn off the ignition. AND....to make matters worse, now that I have a mild cam in in and the engine lopes beautifully, the damn rattle is present when it's idling (800 rpm) and it's really embarrassing. I have checked all heat shields, etc etc that one usually checks during this sort of thing.
When I get under the car a listen, it really sounds as if the "gurgling" rattle is coming either from area of back of oil pan or in front of transmission. It doesn't make any difference if you have clutch in or not.
Any ideas?
Thanks!
Old Jun 5, 2002 | 04:19 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: Rattling Noise (WHRITZY)
Could be the PO installed a single mass flywheel?
Old Jun 5, 2002 | 04:38 PM
WHRITZY's Avatar
WHRITZY
Default Re: Rattling Noise (PeteL)
Pete, don't know for sure....but don't know why he would....car was pure stock when I got it and had 23k on it. Only has 24.5k now.....are you familiar with the noise I'm trying to describe? Go's away at about 1100 rpm....
Old Jun 10, 2002 | 04:06 PM
captainjack's Avatar
captainjack
The same noise in my 85 coupe was caused by the dual-walled front Y-pipe. Your car probably has the same type of Y-pipe. GM made the front Y-pipe with one pipe inside the other for a certain length inside the Y-pipe. When the spot welds break down between the two pipes you get the annoying rattle. My exhaust technician blew thru the outside pipe with a torch on both Y sections in about 3 or 4 places on each pipe. He then proceeded to spot weld the inner pipe back onto the outer pipe and filled the holes completely on each pipe. The end result was no more vibration between the two pipes and thus no noise. Hope this is your problem and you get it resolved.
Old Jun 11, 2002 | 03:27 PM
WHRITZY's Avatar
WHRITZY
Default Re: Rattling Noise (captainjack)
Thanks, Capt. Jack...the theory is good, but I eliminated my front Y Pipe when I installed Hooker Headers with the engine mods....still looking for it...
Old Jun 11, 2002 | 04:29 PM
devilfish's Avatar
devilfish
I got the same noise to. Its the PVC vavle that rattels when you turn of the car and let of som vaccume. Try to take off the pvc valve and start and turn off the car..
Regards
Old Jun 11, 2002 | 06:00 PM
WHRITZY's Avatar
WHRITZY
Default Re: Rattling Noise (devilfish)
I'll give it a shot...thanks...will let you know how I turn out.
Old Jun 12, 2002 | 09:22 AM
devilfish's Avatar
devilfish
:yesnod:
To Rattling Noise
