Frankenengine
Old Oct 31, 2012 | 05:45 PM
Zorro O's Avatar
Zorro O
Default Frankenengine
I Have a 1979 C3 running a 1986 L98 TPI engine with aluminum heads, I do not trust the bottom end on the L98. I also have a GM crate engine 10066036 with bad heads, but a good bottom end. Would putting my aluminum heads, TPI fuel system, and computer controlled HEI, on the crate engine work? Will all the bolts and ports line up? I imagine my compression ratio would be a lot higher. Would the cam work? Will my 700R4 bolt to it? Would this setup be good, bad, or ugly? The car will be used as a cruiser.
This seems to be the crate motor I have.
GM Goodwrench 350ci/260HP Engine & Packages
This universal 350ci engine uses a brand new block and can be used as a replacement for most GM vehicles from 1973-85. It produces 260 HP and 350 ft/lbs torque with a 4-bbl carb and headers.
Specifications
4-bolt main with 2-piece rear main seal
Cast iron crankshaft
LT1/LT4 powdered metal connecting rods
Cast pistons (dished)
Hydraulic flat tappet cam (.383''/.401'' and 112° lobe separation)
Cast iron cylinder heads with 76cc chambers
8.5:1 compression ratio
Block is compatible with left or right side oil dipstick (Requires Plug for Unused Side - Plugs are Included)
4-quart oil pan
Timing tabs for a 6-3/4'' or an 8'' balancer
Recommended spark plug: Accel #111-0574-4 or any spark plug with 14mm .460'' reach, 5/8'' hex, tapered seat, projected tip
Zorro.
Old Oct 31, 2012 | 07:55 PM
JackDidley's Avatar
JackDidley
It will bolt right together. Just need the right flywheel with the shortblock.
Old Oct 31, 2012 | 08:18 PM
Zorro O's Avatar
Zorro O
Thanks, I was planning to use the starter, and flex plate, that came with the crate engine. Any idea if that will cause me any problem with the 700R4? I have swapped a few 4sp transmissions, This is the first time I have ever had to mess with an auto/torque converter.
Zorro
Old Oct 31, 2012 | 09:08 PM
vetteoz's Avatar
vetteoz
In any swap regardless of trans ,the flexplate / flywheel must match the crank style 1 or 2 pce RMS ) being used
Your 86 engine "should" be later model 1 pce RMS ; the crate is is listed as 2 pce RMS.
Old Oct 31, 2012 | 09:18 PM
JackDidley's Avatar
JackDidley
Zorro
Just do it. TPI will have enough torque to make it fun to drive and it will be easy on gas.
Old Oct 31, 2012 | 11:36 PM
DanZ51's Avatar
DanZ51
The two issues:
1. As pointed out you will need a early (2 piece RMS) style flexplate.
2. Your compression ratio is gonna jump going from a 76cc head to the aluminum 58cc. Plan on something like 10.5:1
Personally, I would add a little fatter cam to bleed some of that compression (dynamic) and use a thick head gasket.
Old Nov 2, 2012 | 01:05 AM
Zorro O's Avatar
Zorro O
This all sounds like good news to me. I will start looking for a cam.
Zorro
Old Nov 2, 2012 | 02:35 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
You can swap the heads on if you use premium fuel and retard the timing 5 degrees.
To Frankenengine
