over heating at idle.
Old Nov 16, 2012 | 08:49 PM
pcolt94's Avatar
pcolt94
If the fans are running at those temperatures, that sounds OK an it would not sound like an electrical problem.
If you replaced the thermostat with a correct LT1 stat, then you have to go to the next logical place which would be the radiator.
However;
I am assuming there is no debris blocking the air flow if front to the radiator.
When the engine is cold, check the flow in the surge tank. You should be able to see flow in the tank for the heater core at anytime which indicates the pump is working.
Does the coolant look normal. Just thinking of a possible leaking head gasket. You can buy a check kit from a parts store.
Old Nov 16, 2012 | 09:16 PM
assain618's Avatar
assain618
Coolant looks perfectly normal. It kept dieng on me today 3 times within a mile and it ran ok for .5 miles then died on me 6 times pulling into my neibhorhood and 3 times trying to park it....
Maby have to replace crank sensor?
Old Nov 16, 2012 | 09:44 PM
pcolt94's Avatar
pcolt94
No crank sensor on a 93.
Sounds like you may have 2 problems. The dying problems sounds like the ICM (ignition control module) may be defective.
Old Nov 16, 2012 | 10:01 PM
assain618's Avatar
assain618
Crankshaft position sensor??
We just replaced the opti-spark, ICM, and the coil.
Old Nov 16, 2012 | 10:13 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
hum... did the overheating start AFTER replacing the OPTI?
if so, perhaps the water pump was re-installed WITHOUT the the coupler so actually the water pump is NOT spinning/pumping coolant.
Have you confirmed coolant flow (lower coolant level in pressure tank and confirm flow into tank from small upper hose which enters just below the 'radiator' cap).
Old Nov 16, 2012 | 11:11 PM
assain618's Avatar
assain618
yes, we have coolant flow.
