Parking Brake Exploded View
Old Nov 13, 2012 | 12:00 PM
Charles Terry's Avatar
Charles Terry
Default Parking Brake Exploded View
Does anyone have a schematic of the parking brake for a 1984 Corvette? I have 1 spring that was broke and can not find where it should be connected.
Thanks in advance, 2 projects complete and this remaining and the vette will be back on the road after 4 years sitting.
Chuck
Old Nov 13, 2012 | 12:32 PM
WVZR-1's Avatar
WVZR-1
Chuck
See if this might help. Bottom of page!
http://www.corvsport.com/Corvette/C4...s/Braking.html
Old Nov 13, 2012 | 03:21 PM
Charles Terry
That site is great and have it bookmarked now,what I need is the handle in the car that engages/disengages the brake. Works fine,but I noticed a broken spring, so trying to figure out where it goes.
Thanks for the site!
Old Nov 13, 2012 | 04:16 PM
WVZR-1's Avatar
WVZR-1
There's no parts serviced for the parking brake in the car other than the switch for the light. The earliest part # 14050061 '84 - '86MY only, it appears to change to an '87MY # 14105127 so if you found used from anything '87MY or earlier you should be good.
The switch would likely have a "flat spring" as a part of it. Switch is # 14047181.
Do you have a snapshot of the broken part?
Old Nov 13, 2012 | 04:57 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Not sure if this helps, supposedly for 84-87.. Haven't had to work on mine..
http://www.ebay.com/itm/1984-1987-C4...sories&vxp=mtr
To Parking Brake Exploded View
