about 30 minutes into the drive, the dash wents nuts... segments blinking on and off, all my interior lights turned on, and my radio turned off. I also found my O/D turned on/off with the headlights (but my ECM is pulled so it is purely mechanical. 12v from battery to switch to 1st gear relay to o/d pressure switch)
It drove/ran without a problem. I made it to my spot and shut off the car, looked around under the hood, and tried to restart. Nothing. no lights, buzz, click, etc. not a damn thing.
So I finally had a second to check out the car, hopped in it, turned the key and it fired right up, like nthing was ever wrong.
I was really foggy this morning... moisture somewhere?
When I started it, it seemed fine, about a minute in, the dash went crazy again. 4 miles from my house, after 20 minutes driving, hit a red light, and it was like someone turned the key. Done. Same thing as before.
It's your coil.....When the coil starts to go, it makes the dash go whacky
1- load test your battery
2- clean all connections
3- start going through the ignition system/ lots could be wrong here
4- load test your alternator with a dvom, connect it to battery, have someone start the car, while it's cranking just before it starts if the meter reads 9 volts or less your battery is bad. If you see more or less than 14.5 volts ( when you start it again ) alternator may be under or overcharging killing your battery.
after the trip to my place on the rig, I opened the door to press the brake and slide it off the flatbed and all my lights worked, I didn't have the key on me, so we back it down, and I got my keys, put it in the ignition and then it all crapped out again.
