No traction
Old Dec 3, 2012 | 02:04 PM
marvinator's Avatar
marvinator
Default No traction
I have an 85 vette with 500 hp 460 torque 383 stroker. beefed up 700r4 and 2400 stall speed. yesterday for first time took it out on deserted hwy for run. rolled out to 2000 rpm and nailed it, then shifting to second the car made a radical left turn, got out of gas went back to right then left again til finally under control. running bfg hp tires. my thoughts, rear wing for downforce ,street radil drag tires, letting tranny shift on its own. would appreciate any SERIOUS ideas
Old Dec 3, 2012 | 02:40 PM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
You're kidding... right? Any passenger car with 500 hp without traction control WILL BREAK loose if you punch it... pushing it beyond your own driving abilities. (Even my stock 93/300 hp will break loose.) Did you beef up the original suspension and brakes, too?
You need to learn to handle the beast... and its personalities and quirks. You found its overwhelming HP (strengths) and the tires (weakness).
A recommendation ... driver's school - need to refamiliarize yourself with the improved horsepower.
Also AutoX and roadracing subforums may supply a better insight, too.
http://forums.corvetteforum.com/auto...roadracing-23/
Old Dec 3, 2012 | 03:18 PM
rklessdriver's Avatar
rklessdriver
Just buy a real set of tires.
The Mickey Thompson Drag Radial will hook the car up and drive fine on the street.
I run the MT 315/35R17 on my 92 and get about 8K street miles AND a season of racing (50+ passes) per set out of them.
Will
Old Dec 3, 2012 | 03:49 PM
383vett's Avatar
383vett
A road or highway will have a crown on it. If you lose traction, the rear goes right and the car goes left. Try it at a strip with sticky tires. A rear wing won't help until you are 100mph+, not in 1st gear.
Old Dec 3, 2012 | 10:32 PM
bjankuski's Avatar
bjankuski
Drag radials will help, forget the wing. On a side note what did you expect with street tires and 500hp in first gear?
Old Dec 3, 2012 | 10:35 PM
cv67's Avatar
cv67
St. Jude Donor '05
Old Dec 4, 2012 | 12:57 AM
marvinator's Avatar
marvinator
I expected it to smoke the tires thru 1st gear, which it did, just wasnt expecting to go sideways when i shifted to second
Old Dec 4, 2012 | 04:08 AM
93 ragtop's Avatar
93 ragtop
On mine when I had the 350 hotcam motor making 362 rwhp, when shifting from first to second, it would fishtail very easy. With ET Streets at the track, a short burnout, and even standing on the brake to bring rpm's up, I couldnt break it loose on launch.
As rklessdriver said, get a good set of drag radials and it will be a world of difference.
BTW what are the mods you have done to get that kind of power?
Old Dec 4, 2012 | 06:19 AM
vetteoz's Avatar
vetteoz
On the street , my 410 rwhp 383 A4 will kick the rear on the 1-2 shift @ WOT ( have a very firm shift kit ) on ET streets.Just need to be prepared for it
But doesn't do it at the strip
Old Dec 4, 2012 | 07:20 AM
RVY's Avatar
RVY
Find your self a set of beam plates. That will/should cure the kick out to the right when shifting from first to second. At 400 rwhp I usually got traction toward the end of second gear. At 600 rwhp I stopped going to the strip. Don't expect much from '"STICKY TIRES". And avoid advise from those making less than 500rwhp. They simply don't understand because they have never been there. Enjoy and stay alive!
Old Dec 12, 2012 | 05:13 PM
91monsta's Avatar
91monsta
get some zr1 11 inch wheels with m/t 315s like what rklessdriver said might need the 36+ offset i think cause of year
To No traction
