close to 12 Sec. 1/4
i would be more than thrilled if i picked up .5 on the 1/4 that would put me well in the 12's, more than anything i am tired of the motor falling off at about 4000 i know with the cam and heads i can pull to 6000 with the right intake
I brought the vette to race in the ECSCC at Etown, back in 2005. The compression is 10.1 The stock engine ran 14.1s I had no plans of keeping the stock engine. When I installed the engine with the stock TPI, the car wouldn't run quicker than a 13.7 I intake would not flow enough air. I went on line and learned how to do a LT1 conversion swap.
Your car should pick up some HP, but it depends on how much air your heads can flow.
currently with the tpi and stock manifolds i have laid down a 13.05 @110 so once i start uncorking the power the car should pick up quite well.
i do have a set of dart 200 cc 2.02 1.60 heads but they are strait plug and i do not think the will fit the manifolds / headers
My combo has change but check my Sig.
Randy
My vette with the 383 219 LPE cam, 113 heads, stock TPI, and stock manifolds without slicks ran a 13.0 @ 110.
What can i say Corvettes are just better cars lol
ran a 12.79@111MPH on a nitto 555 street tire.
Should run better next time i found a blow RR shock so i installed a set of Bilstens i had in the shop.
I am running a M6 (ZF6) so that makes it a challenge getting the car moving off the line. stock rear gear with a 3.33 would like a 3.75 or 4.11 at some point.
Course I don't have a stock TPI intake either. (Edelbrock base and runners, ported plenum) Nothing else I've done to this car, got such a big gain in ET.
I'm hoping this April I'll be able to find another few tenths. Providing things don't go to *** between now and then (my dad's health is starting to look questionable) I'm getting my cam, and a dart 400 shortblock with Mahle internals, and a vigilante 2400 stall converter. Should be a hold onto your *** car after that
It'd be even better if the AS&M runners came in too around then...
Minimum a heavily worked over superram .
Course theres always the FIRST if you love the longtubes. Dont choke a 400 down they are too much fun and can use plenty of intake you wont lose any tq
The typical TPI long tube setups even worked over will do a disservice to those cubes
I would have to go with a FIRST if I switched it out the rest of the way. The TPI runners look great. And the AS&M runners will give me the missing flow anyway. Assuming they ever do another run for them. (they actually flow a little better on the runners than the FIRST does) The edelbrock base has plenty of room left in it for porting yet too which was a vast improvement over stock. And I don't think an LT manifold is going to thump out 515 ft lbs there abouts at 2500 rpm.
There's an aesthetic with the runners I'm trying to maintain as well. The AS&M runners would be Ideal...if they'd ever make another freaking run on them. If someone didn't look to close, I'm trying to go with a car that at first glance, you'd think it was just another old L98 with some headers, and a true dual exhaust thrown on it.
The reason I'm going with the dart shortblock kit, is because the 350 is questionable right now. with 148,900 (and definitely will be at 150,000 by April) and 25 years on it, and a previous owner who let the intake gaskets go, I don't have a whole lot of faith in the bottom end for future mods, like putting Boost to the engine.
It's held up well so far, but it's a really old engine, and this car was abused before I got it. I doubt the previous owners even put synthetic in it. Between the intake gasket which was so bad that the car popped and knocked at Idle, and the brake fluid that I'm pretty sure was from 1989 when I got it... my faith in the bottom end of the L98 isn't there you know?
