Just stops while cruisin?
Old Dec 10, 2012 | 02:27 AM
Killer51's Avatar
Killer51
4th Gear
Default Just stops while cruisin?
Hello All,
I have a 1984 Cross fire injected corvette and im in Australia, no one here seems to know much about the cross fire injeced engines, i have had the car for 3 years, while the peformance isn't that great i still love the car, the last 2 times i have driven the car it seems just to stop running while i am driving, like there is no power?? I try to turn it over and it turns with out starting, i then leave the car for ten to 15 minutes and it will start first time and drive for a bit more then die?? has anyone had these problems? also what simple mods can you do to give the crossfire more power?? 1st question is more important though as i can't have it keep stopping, any help or pointers will be greatley appreciated.
Old Dec 10, 2012 | 06:17 AM
AirForceOne!'s Avatar
AirForceOne!
When you say stops running and has no power, do you mean electrical or no fuel?
Old Dec 10, 2012 | 06:57 AM
ex-x-fire's Avatar
ex-x-fire
Yeah, when it dies check for spark, fuel spray (inj. pulse), & fuel pressure.
Old Dec 10, 2012 | 08:24 PM
Killer51's Avatar
Killer51
4th Gear
Originally Posted by Killer51
Hello All,
Im not sure iof it is fuel or spark thats why i asked if any of you guys have had this problem? it drives fine then just loses power? my cousin had a similar problem with a newer car and it was the crank sensor, will look at that or if anyone else has had similar problems please share to help me solve this annoying problem
Old Dec 16, 2012 | 10:46 PM
Killer51's Avatar
Killer51
4th Gear
I have since found out it was the Ignition Module inside the Distributor, if anyone has the same problem look there first
Old Dec 17, 2012 | 02:10 AM
hemivett's Avatar
hemivett
I always carry a spare, as they usually go out without warning. Im surprised yours started back up. h
Old Dec 17, 2012 | 08:52 AM
AirForceOne!
Glad you got her running again!
To Just stops while cruisin?
