93 project car purchased 3 months ago. put new battery in remote and it will open the rear hatch fine but will not lock / unlock doors. doors do not lock from inside door buttons either. can hear some slight movement in drivers door but nothing opens. any help on this is appreciated. thanks
For beginning information check the fuses for the door locks.
If neither side will lock electronically from the manual slide switch, that might indicate a that the problem might not be with the door switches themselves but a common problem.
The PKE receiver is in the loop of operation of the door locks. I believe the door switches actually activate a relay in the PKE to operate the door solenoids to open and close the door.
So before ripping into the dashboard for the PKE, I would check out all other connectors, voltages and other related items first. This problem has nothing to do with the PKE programming but an actual problem of activating the door solenoids which is basically running around looking for 12 volts at the proper places and related grounds.
jim, thanks for the link. system cycled as described but doors will not lock from inside the car from either side when the lock button on the door is moved back and forward. any other thoughts.
