Rear end not right...struts??
Old Dec 16, 2012 | 08:53 AM
locknessmonster's Avatar
locknessmonster
Default Rear end not right...struts??
Hey guys. Just wondering if anyone can shed some light as to why my 84 vette is so rough esp over bumps. Feels like the rear is the problem. Could it be struts possibly? Thanks for any help!
Old Dec 16, 2012 | 08:57 AM
ex-x-fire's Avatar
ex-x-fire
That year had very stiff springs, do some reading on here, they cut the spring rates alot for 1985.
Old Dec 16, 2012 | 09:26 AM
leesvet's Avatar
leesvet
springs.
84 had the stiffest of ANY C4 Corvette by 2:1
Old Dec 16, 2012 | 09:57 AM
locknessmonster
Oh ok that makes sense then. Any idea on which ones I shiuld b looking into getting? Thanks guys
Old Dec 16, 2012 | 10:36 AM
fredd1's Avatar
fredd1
New shocks and lowering the tire pressure might help a bit, but the spring stiffness on the '84 is probably more suitable for the track or a smooth highway than normal street driving with uneven pavement. Still you gotta love it on the corners.
Old Dec 16, 2012 | 01:16 PM
383vett's Avatar
383vett
I changed out my 84 Z51 springs to 85 springs. Made a world of difference.
Old Dec 17, 2012 | 07:53 AM
locknessmonster
Yeah thats what I was thinking... are the Bilstein shocks the way to go?
Old Dec 17, 2012 | 12:12 PM
c4cruiser's Avatar
c4cruiser
The front spring is also pretty stiff especially if the car has the optional Z51 suspension. And half of the entire 84 production run had Z51. Does your car have the Z51 suspension?
If you are going to consider softer springs, then you should swap out both front and rear springs. Softer shock can help some, but I would match the shock to the spring type. IIRC, the 84 used an AC Delco shock for the base suspension and Bilsteins for the Z51 package.
Bilstein makes a "Sport" shock" and a "Performance" (also called Xtreme by Vette Brakes) shock. The Sport shock will be slightly stiffer than a base shock and the Performance shock is for the Z51
Old Dec 17, 2012 | 12:33 PM
DanZ51's Avatar
DanZ51
Corvette spring rate chart:
http://corvetteactioncenter.com/tech...l#.UM9W3qzhfnI
Old Dec 17, 2012 | 12:47 PM
locknessmonster
I do not have the z51 package. So go for bilstein sport shocks maybe?
Old Dec 17, 2012 | 01:46 PM
garryowen's Avatar
garryowen
Originally Posted by DanZ51
THANKS SO VERY MUCH DAN
one of my next summer projects will be tackling springs and have been to busy to look up chart
To Rear end not right...struts??
