Two quick questions..on c4s
1) Can a C4 be driven onto a U-Haul trailer without any damage? The rental guy has no clue and is only interested in what kind of truck will be used to pull the trailer. (Silverado Z71 4 x 4)
2) At what temperature should the fans kick on? I looked at a 96 LT1 with 115k miles that almost pinned the needle to overheat, then about a minute later it cooled to about 200 degrees. Outside temp here was about 40 degrees.
Thanks!!
As for number 2, I have no clue, I don't drive in the city.
1: low on coolant - have it pressure tested for leaks
2: failing thermostat
3: mostly or all water in cooling system (see#1) and was frozen overnight- once the engine melted the ice, water circulated and cooled the engine rapidly. Check the freeze plugs (if it has them). Could lead to, or have, blown head gaskets or worse if its been like this for awhile. This could be a case of owner neglect.
4: best case scenario, faulty coolant gauge temp sensor
Good luck, have it very thoroughly checked by a pro if you want to pursue this one!
Don't rely on the tie-downs that come with the trailer. Either ask for new ones or bring your own. Lowes and Home Depot will have decent tie-downs with snap hooks.
When you look at coolant temps, look at the digital display; the analog gauge may not be correct and because it's non-linear, the temp reading at the high end is hard to determine.
The secondary fans should kick on at around 238 degrees and run until the temps drop some 35-40 degrees. It could be that there is debris in front of the radiator and A/C condenser that reduces air flow. It could als be time for a complete cooling system flush and fill.
Fans behaved properly and handled the situation correctly.
If you feel that the temp rose rapidly in a " cool" environment, begin checking for debris blocking the flow from underneath, as these are mouth breathers.
Check the simple first!
Then move on to the more complex.
Good luck!
And let us know what you observe at each step.
If the A/C is on, both fans should be on all of the time , preventing such a rapid rise.
Check that out first.
Marty
1FUNZR1
I removed the front lower black air dams also. I also looked for some slope to park the trailer so that the ramps wouldn't be quite as much angle.
It worked for me about 1700 miles each way (IL to AZ then back to IL) with no damage to the car.
Good luck.
Thanks!!
The primary coolant fan kicks on at 228* and the secondary at 230*.
Also make sure your trailer lights work and you have the proper connectors for the trailer/tow vehicle. The one I had said "50mph limit"; I may have exceeded that once or twice on my trip.
AND...when the fans come on @~228 or so, the ANALOG gauge will be darn near the red. Terrible design and very misleading. The ANALOG gauge is only meant to show an "estimation" of the situation (not just the temp, either, it's all of them) so they are fairly worthless. You gotta consult the DIGITAL display for the true, accurate readings. This is true for oil pressure, coolant temp, and volts.
Thanks!!
I removed the primary and secondary cooling fans and cleaned and inspected them as well as the connections.
The previous owner had also rigged the air deflector due to the lower lip of the radiator support on being busted off. To ensure absolutely factory correct air flow to the radiator, I rebuilt the front air deflector, replaced the lower radiator support and installed all the correct brackets. and completely cleaned out all the debris.
When idling in traffic, or in my driveway, the temp gage on the dash will get almost to the hatched area (228-230 F) and then the cooling fans kick in until the temp drops to 213 F. Then they shut off. The temp starts rising again until 228-230, then the fans kick in. While sitting in traffic I literally watched the system cycle like this via the gages repeatedly and consistently. I could almost set my watch by it.
The analog gage is an estimate, use the digital gage for exact temp. But the analog followed the digital perfectly.
Typically when driving 55-65 mph the temp will be in the 200-210 range depending on speed. It will occasionally get up to 210-215 or down to 190-200 depending on the speed.
So 2) sounds normal to me.
On the '96 both fans run at the same time, either low or high.
Page 6-639
104°C (219°F) and OFF at 98°C (207°F) and, high
speed fans ON at 109°C (228°F) and OFF at
103°C (214°F).
It will run like that for as long as your sitting still.
I used the curb method to load the car.
No drama on the drive from Colorado to the swamp
As for the C4 coolant system. As RollaMo-LT4 posted its designed to run at higher temperatures than previous generation vettes. I'm sure most modern cars are designed the same way, however, most use idiot lights or gauges marked C and H on them so the operatiors are unaware of actual temps.
Mike
