Oil Filter Comparison (Condensed Version)
Old Jan 7, 2013 | 04:56 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Oil Filter Comparison (Condensed Version)
The mission is to find the best filter at the best price by examining the internals for quality of construction and materials.
Then you can decide which brand is best for your wallet.
The baseline filter I'm thinking of is for the SBC L98 engine.
Lots of choices out there. Seems the choice between shortys and standard is to be determined.
Donated by JrRifleCoach
4" Wix 51060 $7.71 4.0" x 84.5" = 338 sq in. Can Thickness .011"
4" Fram PH5 $3.77 3.85" x 50" = 192.5 sq in. Can Thickness .011"
3" Purolator L34631 $3.27 3.0" x 93.5' = 280.5 sq in. Can Thickness .011"
3" Fram TG30 $6.99 3.0 x 64.5 = 193.5 sq in. Can Thickness .010"
3" Fram PH30 $3.77 3.0" x 50.0" = 150 sq in. Can Thickness .010"
3" Napa Gold 1069 $6.19 3.0" x 87.5" = 262.5 sq in. Can Thickness .011"
2" STP S9973 $3.59 2.1 x 84.5 = 177.5 sq in. Can Thickness .011"
2" Bosch 3322 $6.99 1.75 x 97.5 = 170.6 sq in. Can Thickness .011"
2" Mobil M1-111 $12.99 1.95" x 83.0" = 161.85 sq in. Can Thickness .011"
Donated by Kubs
3" Wix 51069 $0.00 3.0" x 87.5" = 262.5 sq in. Can Thickness .010"
4" Wix 51060R $0.00 3.75" x 62.5" = 234.4 sq in. Can Thickness .016"
2" Amsoil EA059 2.0' x 61.0" = 122 sq in. Can Thickness .011"
Notes
Three different height filters 4", 3" & 2" All referenced as the fit for the 86.
The observed quality of components and construction is apparent.
See what your paying for and how it stacks up against the competition.
Old Jan 7, 2013 | 04:58 PM
JrRifleCoach
The Wix 51060 and Fram PH5
After removing a section of filter media for measurement
NOTE: The inner tube was securly fastened on the Wix.
The Fram tube was lightly glued to the cardboard end caps and fell apart in my hands.
Media Surface Area
Wix 4.0" x 84.5" = 338 sq in. Fram 3.85" x 50" = 192.5 sq in.
Old Jan 7, 2013 | 04:59 PM
JrRifleCoach
Fram PH5 and Purolator L34631
Fram 3.0" x 50.0" = 150 sq in. Purolator 3.0" x 93.5' = 280.5 sq in.
Old Jan 7, 2013 | 05:00 PM
JrRifleCoach
Mobil1 M1-111 and Amsoil Ea059
Mobil1 1.95" x 83.0" = 161.85 sq in. Amsoil 2.0' x 61.0" = 122 sq in.
The Amsoil filter media was very different form the others. First the use of metal screening. I'm guessing this is added to support the filter media. Second the actual media which is rather thick and "fluffy" like soft paper. Such a small filter and surface area. Not what I'd consider useful for hi volume/flo applications.
Old Jan 7, 2013 | 05:03 PM
JrRifleCoach
As expected the NAPA Gold and the WIX are identical.
Old Jan 7, 2013 | 05:04 PM
JrRifleCoach
The differences between the "R" and standard duty filter prove WIX's priority to build a solid racing product. The can is thicker as is the base and the flange to hold the rubber seal. The filter is shorter by 1/4" to accommodate a much heavier spring.
Old Jan 7, 2013 | 05:05 PM
JrRifleCoach
Opening the last two filters of the group revealed another surprise in construction. STP's filter caps were constructed from a heavy guage synthetic fibre that is bonded to the filter media. And the center support tube is a polymer basket construction. The Bosch exposed what we've seen so far as conventional construction. Nothing out of the ordinary that would suggest it as an inferior product.
Sad but not surprised the 3x to 6X Tough Gard upgrade filter only contained a few extra folds of filter media.
Old Jan 7, 2013 | 05:09 PM
JrRifleCoach
Just a bit of spare time to condense the previous thread.
And some requests for an easy show and tell thread prompted me to rebuild.
Old Jan 7, 2013 | 06:47 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Great comparison thread!! Thanks for taking the time to do this.
Old Jan 8, 2013 | 02:00 AM
JrRifleCoach
Many thanks for your donations.
On to my next project........ any one have a spare shock dyno laying around?
Old Jan 23, 2013 | 11:13 PM
JrRifleCoach
Found this pic in a recent email.
It's a very impressive array of filters, just not sure if the fitment is for one engine.
If you look closely the AC Delco filter has the same plastic basket center as does the STP and Super Tech (WalMart?) Yikes?!?
Old Jan 23, 2013 | 11:17 PM
JrRifleCoach
Bummer.....
Old Jan 23, 2013 | 11:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
Nice work there JR
I know I flaked on sending mine out ergh...
Watch the whole thing
Old Jan 24, 2013 | 12:20 AM
JrRifleCoach
Looks like Fram is just another four letter "F" word in his book!
Old Aug 13, 2014 | 11:18 AM
JrRifleCoach
Bump for those....
Old Aug 14, 2014 | 02:06 AM
Black LS2's Avatar
Black LS2
Nice comparo!
The most media is not the only key factor; many filters go into filter bypass mode if the media creates too much flow resistance...self defeating.
Nearly certain I killed the camshaft on a bike once using a Bosch über filter where the engine and filter combo had limited or no bypass capability.
Old Aug 14, 2014 | 03:03 AM
Cliff Harris's Avatar
Cliff Harris
This site shows the construction of a bunch of oil filters and who actually makes the various brands available:
http://www.minimopar.net/oilfilters/reference.html
To Oil Filter Comparison (Condensed Version)
Old Aug 14, 2014 | 07:22 AM
jodester's Avatar
jodester
St. Jude Donor '14
Just wanna say thanks for the effort put into this. I absolutely love these types of posts, very well done. Thanks.
Old Aug 14, 2014 | 10:57 AM
JrRifleCoach
Nice bump Cliff.
Old Nov 12, 2014 | 08:43 PM
larryfs's Avatar
larryfs
I'd like to see a cutaway of the Fram Ultra. It's supposed to be one of the best.
