**New Performance Optispark for your LT1/LT4!**
Old Jan 10, 2013 | 04:58 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default **New Performance Optispark for your LT1/LT4!**
ProComp Optispark for LT1/Lt4
CHEVY LT1 10000 SERIES DISTRIBUTOR
OEM Replacement Distributor is designed for enthusiasts that are serious about performance.
precision tolerances, high strength and incredible endurance.
Under the brass terminals of the cap and rotor is an extremely accurate Optical eye which never requires adjustment.
The 1/2' steel shaft that spins the Rotor is guided by a sealed ball bearing and long sintered bushing.
This combination provides stable timing signals and spark delivery at any RPM.
1 year warranty!
Only $159.95 http://www.saccitycorvette.com/LT1-SBC-IGNITION.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Jan 12, 2013 | 01:11 AM
HighMileage's Avatar
HighMileage
How reliable is this?
I have read that many aftermarket optis do not use the same sensor element (forgot what its called) that the Delco units used and as a result fail.
This price is killer if it works better than oem. Does it accept stock cap and rotor?
Old Jan 14, 2013 | 02:13 PM
SacCityCorvette
Supporting Vendor
Hi HighMilage,
I believe the stock cap and rotor will fit, but it does come with a heavy cap and rotor.
They must be pretty confident in it reliablitity to give a 1 yr warranty. I don't believe you get that from a GM opti.
Old Jan 15, 2013 | 02:53 PM
93 ragtop's Avatar
93 ragtop
[QUOTE=SacCityCorvette;1582828794]Hi HighMilage,
They must be pretty confident in it reliablitity to give a 1 yr warranty. I don't believe you get that from a GM opti.[/QUOTE]
If it turns out to be reliable, and I hope it does, I wouldn't be too concerned about using a stock cap and rotor on it. Heck they cost about as much as you are selling the whole opti for!!
Edit to say, Thanks and glad to see someone bring LT1-4 parts to the market.
Old Jan 16, 2013 | 09:55 PM
TorchTarga94's Avatar
TorchTarga94
Old Jan 17, 2013 | 12:00 PM
SacCityCorvette
Supporting Vendor
One Year Warranty! Non race of course.
Old Jan 23, 2013 | 07:48 PM
SacCityCorvette
Supporting Vendor
I know some of you have your doubts about this ProComp Optispark. I think if it were a product with a lot of defects it would be all over the internet. I'm sure every brand of opti (even GM) has its failures. Just saying!
Old Feb 15, 2013 | 01:16 AM
SacCityCorvette
Supporting Vendor
These Opti's have a one year warranty! Quality looks really good!
Old Mar 6, 2013 | 12:11 PM
SacCityCorvette
Supporting Vendor
We are using one of these ProComp Opti's on our 97 supercharged Z28 Camaro. Its working fine!
Old Mar 27, 2013 | 08:40 AM
walltoddj21's Avatar
walltoddj21
5th Gear
Opti sparks are New Lifetime Warranty at Autozone for $229 #84-1832 cap, rotor and new assy. Cap and rotor are $199 # DR2032 alone with 5 Year.
Old Mar 28, 2013 | 12:42 PM
SacCityCorvette
Supporting Vendor
ProComps Opti also comes with cap and rotor.
Old Mar 28, 2013 | 01:22 PM
walltoddj21
5th Gear
Ok so I see you sell them $125.95 but what kind of warranty. This is in a daily driver so if I have a problem anywhere I take it back and get a new one for life.
Old May 14, 2013 | 07:45 PM
SacCityCorvette
Supporting Vendor
So Far we have not had to warranty any of the ones we have sold.
Old May 17, 2013 | 02:23 PM
SacCityCorvette
Supporting Vendor
Sorry, missed your question. They have a one year warranty.
Old May 17, 2013 | 02:30 PM
SacCityCorvette
Supporting Vendor
I think you should start your own post to promote autozone!
Old Jul 17, 2013 | 02:54 PM
SacCityCorvette
Supporting Vendor
One Year Warranty!
Old Jul 28, 2013 | 02:55 AM
BlackRaTT's Avatar
BlackRaTT
Originally Posted by SacCityCorvette
ttt
Is there a Member price? I am about to purchase an Opti unit.
To **New Performance Optispark for your LT1/LT4!**
Old Jul 29, 2013 | 01:24 PM
SacCityCorvette
Supporting Vendor
Hi BlackRaTT,
The price in the above ad is the member price.
Christian
Old Aug 7, 2013 | 07:10 PM
SacCityCorvette
Supporting Vendor
Hey everybody, We have one of there one our turbo camaro with a msd box and blaster coil which is know to burn out optisparks and our is still going strong!!!
Old Aug 13, 2013 | 03:30 AM
SacCityCorvette
Supporting Vendor
Hey everybody, We have one of ProComp Opti's on our turbo Camaro with a msd box and blaster coil which is know to burn out optisparks and our is still going strong!!!
Matt
