L98 Intake Removal/Porting?
Old Jan 22, 2013 | 02:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
post up your impressions on how it runs wiht that intake think youll be pleasantly surprised.
Didnt know theres 4 ways to port a tpi lol
Old Jan 22, 2013 | 08:56 AM
ch@0s's Avatar
ch@0s
Originally Posted by Ziggy91
EDIT: My runners look exactly like those in the pictures that "ch@0s" attached above.
Those are the partially Siamesed runners. I finished them up but they were half way done.
Old Jan 22, 2013 | 12:25 PM
Ziggy91's Avatar
Ziggy91
ch@0s... Why do you even bother with L98s when you've got that LSX going? lol
Dream build for me... I'm just waiting for the opportunity to strike and get it going. Usually for me, this is in the form of really cheap parts or something breaking.
Old Jan 22, 2013 | 01:32 PM
ch@0s's Avatar
ch@0s
that was my old set up. I then went with an HSR and when my L98 gave up the ghost I went LSX.
Old Jan 22, 2013 | 01:40 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Thought we'd talked about this years ago....
SLP had an initial version of their runners that were fully siamesed on two pair. The other two pair were left alone. It certainly LOOKS like that's the version you had -- even if you pulled the other two dividers out.
If I didn't mention it on the prior page (of this thread), the idea was to "tune" 4 cylinders with extra low-mid performance while "tuning" the other 4 cylinder with extra mid-high rpm performance.
"Quality" on early SLP castings has frequently been reported as shoddy...which could explain the observations Ziggy saw.
Old Jan 22, 2013 | 01:43 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Mine after hours of porting. Do it, you wont regret it.
ch@0s, how did you gasket/seal the runners with the mating surfaces being so thin?
I have a set of ported Edelbrocks that are almost identical to yours and have been reluctant to install, for that reason.
Old Jan 22, 2013 | 02:59 PM
Ziggy91's Avatar
Ziggy91
Sorry Greg, I do remember your post. They are more similar to the ones from ch@0s, but not as heavily ported. Probably because of the lack of area for a gasket to seal properly. There are tool marks on the inner parts of the runner, which are very uneven and inconsistent with the other runner. I did my best with carbide bits at work to smooth it out and polish what I could reach. My biggest thing was getting them clean... the entire intake system down to the heads was absolutely filthy.
Old Jan 22, 2013 | 06:25 PM
ch@0s's Avatar
ch@0s
Yup that's what I meant.. I only had to siamese two of the four runners.Therefore they were half way done.
They sealed up just fine. I only touched two of the runners the other two were already like that.
Old Jan 22, 2013 | 07:38 PM
leesvet's Avatar
leesvet
Because this is a low pressure passage, the runner gaskets have zero stress on them from the inside. These would probably seal with a bead of RTV.
Old Jan 22, 2013 | 08:50 PM
Ziggy91's Avatar
Ziggy91
As a member had asked, I took her out for a drive today after work.
As other's had said, the difference in performance is minimal... sadly. BUT, it feels and sounds much better since I replaced the aged gaskets that had been leaking... so I'm happy. Sprayed some water around the eges of the intake and maifold, and surely the car kept it's steady idle, unlike before. I was worried about the injectors leaking, but they're also ok. I don't have hesitation, and it almost seems quieter in the cabin.
If someone's thinking of doing this, porting isn't necesary... but at least cleaning out the filth and replacing the gaskets will restore some ponies.
Old Jan 22, 2013 | 08:57 PM
ch@0s's Avatar
ch@0s
Add a mid range cam and wake that puppy up.
Old Jan 22, 2013 | 10:58 PM
Ziggy91's Avatar
Ziggy91
I'm definitely going with an LT1 intake in the future to keep it looking stock with the covers, and at the same time I'll be changing out the cam for either an LT4 hot or ZZ9 as a member had suggested recently. My goal is only 300hp so I'm not planning on anything expensive.
Old Jan 22, 2013 | 11:08 PM
  #33
cv67's Avatar
cv67
St. Jude Donor '05
LT1 probably the best improvement + any header you can make.
Porting does help TPIs but they have to be done to death to really see it.
Even at that probably wont get what youd think as far as SOTP,
Most runners are a nightmare to get inside the turn so it bottlenecks you have to get creative or be enough to spend the time on it.
