C4 Idiling Problem
Old Jan 21, 2013 | 02:00 PM
greddyrcng's Avatar
greddyrcng
Default C4 Idiling Problem
when you start the car up it goes straight up to redline you have to shut the car off or it will blow the motor please help me here
Old Jan 21, 2013 | 02:08 PM
84VetteMan205hp's Avatar
84VetteMan205hp
the year would help
Old Jan 21, 2013 | 02:16 PM
BBLACKHURST's Avatar
BBLACKHURST
Have you checked the Throttle cable to make sure its not stuck open?
Old Jan 21, 2013 | 03:12 PM
John A. Marker's Avatar
John A. Marker
Check TB cable.
Most likely cause is MAJOR vacuum leak. Check all lines including brake booster line.
Old Jan 21, 2013 | 07:57 PM
Corvette40's Avatar
Corvette40
Originally Posted by John A. Marker
Check TB cable.
Old Jan 21, 2013 | 11:05 PM
pcolt94's Avatar
pcolt94
This may be a good place to start and makes sure the throttle plates are closing.
From the profile it sounds like an 85 with some kind of mod.
Also check the IAC motor for a problem.
To C4 Idiling Problem
