More Superram fun
Old Feb 1, 2013 | 10:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default More Superram fun
Going on another 383 C4 XFI 280 (pretty sure) AFR 195
Little more cleanup work needed and shes done
Old Feb 1, 2013 | 11:03 PM
383vett's Avatar
383vett
looks nice. It'll run well
Old Feb 2, 2013 | 12:29 AM
84wannabezo6's Avatar
84wannabezo6
Is it hard to seal the intake to runner with those thin walls? do you use different gaskets?
Old Feb 2, 2013 | 12:39 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
:ears
Old Feb 2, 2013 | 12:40 AM
JrRifleCoach
:lurk
Old Feb 2, 2013 | 12:41 AM
JrRifleCoach
Sorry just got home from a VFW meeting...
Old Feb 2, 2013 | 04:46 AM
C409's Avatar
C409
..... I went to one of those "meetings" once ... lots of Wild Turkey and PBR ..... ..............
Old Feb 6, 2013 | 11:07 AM
cv67's Avatar
cv67
St. Jude Donor '05
It should work good as well as the prior one.
I know boring, been done 1000 times lol
It will seal fine
Cant use stock gaskets if thats what you mean .
Think Mr Gasket makes a set through Summit
Old Feb 6, 2013 | 04:15 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
I know boring
Ron, you're never boring!
Old Feb 6, 2013 | 11:51 PM
tpi 421 vette's Avatar
tpi 421 vette
Looks good Ron
Old Feb 8, 2013 | 01:54 AM
cv67's Avatar
cv67
St. Jude Donor '05
didnt get too caught up on pretty this time around more function than anything.
If anyones interested there will be a ported FIRST coming soon and a SR with some real hacking and welding going on.
Shooting for 400rwhp Ca smog compliant.
Glutton for punishment
Old Feb 8, 2013 | 05:34 AM
red L98's Avatar
red L98
Prettyyyy ;-)
Old Feb 8, 2013 | 09:00 AM
Vincentiroc's Avatar
Vincentiroc
This is the same combo as yours but its a 355. The manifold has been welded up and the runners has been siamesed with an inch of runner left.
Old Feb 8, 2013 | 09:29 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Old Feb 8, 2013 | 11:28 AM
Dyno Don L.'s Avatar
Dyno Don L.
If you notice, they both drop off at around 5700-5800.
I have been using the 305 manual bin for tuning.
I have since found the Corvette manual bin (thanks to Orr) and will be redoing all the stick cars with it.
Kevin91z and I have installed it in our cars and it made a big difference in driveability so I hope it will cure the cut off at RPM we have had.
The auto cars do not have the problem.
Mean while back to the dyno........
Old Feb 8, 2013 | 01:03 PM
Orr89rocz's Avatar
Orr89rocz
Good to hear it helps .
Super rams are good looking intakes but man i never want to install a tpi or superram again after being spoiled with my hsr and singleplane efi. So quick and easy lol
Old Feb 8, 2013 | 01:19 PM
ch@0s's Avatar
ch@0s
I think it took me as long to modify my HSR as it did to bolt up my TPI.
To More Superram fun
Old Feb 8, 2013 | 02:17 PM
Vincentiroc
I had gotten good at it. I did it in just under 30mins. Installing the Miniram in 10mins. It may perform on the streets better but the Miniram will do just fine if tuned right. I don't think you could tell that much difference on the streets on radial tires from a dig anyway without spinning the tires. Maybe in the upper midrange.
Old Feb 8, 2013 | 02:31 PM
Orr89rocz's Avatar
Orr89rocz
To be honest i changed my turbo setup to push more power into the higher rpm range and move torque curve up as well, bleeding off a ton of low end/midrange torque. Larger turbo housings moving spool point higher as well and to be honest car is loads more fun to drive because it actually hooks up! When you have traction a car can feel very fast lol
Having a 4" cowl hood, i can fit any intake i want so that helps but one or 2 piece intakes are a breeze to work on lol
Old Nov 21, 2013 | 09:04 PM
91blkvette's Avatar
91blkvette
[QUOTE
It will seal fine
Think Mr Gasket makes a set through Summit[/QUOTE]
Which P/N?
