Need Code 23 Help
Old Feb 3, 2013 | 04:26 PM
cumbercr's Avatar
cumbercr
Default Need Code 23 Help
My 85 is having trouble idling when cold. I did a scan and found a Code 23 (Manifold Air Temperture Signal Voltage High). The ECM will not go into closed loop. Does the Code 23 prevent the ECM from going closed?
I'll be testing the harness to the MAT for correct voltage from the ECM but unfortunately the MAT sensor is on the bottom side of my Super Ram plenum. Testing the sensor resistance in place could prove to be a challenge.
Old Feb 3, 2013 | 07:43 PM
ex-x-fire's Avatar
ex-x-fire
Thats the place to start, the wiring could have issues somewhere, you might have to test the resistence between the sensor & the ecm.
Old Feb 4, 2013 | 02:40 AM
vetteoz's Avatar
vetteoz
The MAT has a short extension harness that runs too the main harness at rear.
http://forums.corvetteforum.com/1582020529-post7.html
If you disconnect the harness end you should easily be able to put a DVM on the wires to the MAT
http://forums.corvetteforum.com/c4-t...nny-stuff.html
http://www.chevythunder.com/mat_code_23.htm
Old Feb 4, 2013 | 07:10 AM
C409's Avatar
C409
......... On the early MAF controlled TPI motors , the ONLY function of the MAT is to help control the EGR ... the MAF sensor by design includes intake air temp in its feedback to the ECM ... so a malfunction in the MAT circuit would not affect idle quality but will set the CEL ....... code 23 is usually caused by an open circuit ( sensor not plugged in ) ... as mentioned there is a two-wire weatherpack connector to the drivers side of the rear of the engine near the oil pressure sender ... but , with a SR it may be near impossible to see let alone touch .........
To Need Code 23 Help
