fuel pump
Old Apr 16, 2013 | 03:49 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Before I replaced the pump, I would ensure that there is power getting to the pump. I would do that because I don't like spending money on unnecessary parts.
Old Apr 17, 2013 | 08:09 AM
vet1988's Avatar
vet1988
Cruising
How do I do that? I am not a mechanic.
Old Apr 17, 2013 | 06:02 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Get your hands on a test light if you don't already have one. Pull harness at pump, attach test light lead to ground,...check for power at pump harness.
Old Apr 18, 2013 | 08:41 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by AGENT 86
Is there 12v+ on both sides of fuel pump fuse, when ignition is switched to "RUN" ?
Old Apr 18, 2013 | 09:34 AM
vet1988's Avatar
vet1988
Cruising
Where is the pump harness?
Old Apr 18, 2013 | 10:58 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You can do what Agent86 is recommending -it's easier and faster, but doesn't prove that power is making it to the pump.
The pump (and therefor the harness for it) are located at the back of the car. Pump is in the tank, harness runs to it at the top of the tank. Should be a 3 pin plug there. Did you read the link that 84vetteman205hp posted? There are pics and description that answer many of your questions. Look again, HERE.
Old Apr 20, 2013 | 12:35 AM
aklim's Avatar
aklim
I don't own that thing. I prefer to use a DVOM.
Old Apr 20, 2013 | 02:38 AM
vetteoz's Avatar
vetteoz
Originally Posted by vet1988
Changed the fuel pump relay. Still tries to start but don't hear the hum of the pump. .
Key on ; the pump only runs for 2 sec then turns off
If your oil pressure switch is working correctly it should run again as soon as you crank the engine over
Old Apr 20, 2013 | 05:44 AM
aklim's Avatar
aklim
How about hooking up a known good battery to the fuel pump and see if it does work or not and what pressure it maintains? Noid light only tells you that there is voltage. I'd rather know what the voltage is.
Old Apr 20, 2013 | 10:54 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
But was tying to help a non savvy guy in the easiest, cheapest way possible. You're right that the DVOM is better, but you need to know how to operate it.
