fuel pump
Old Feb 26, 2013 | 02:28 PM
vet1988's Avatar
vet1988
Cruising
Default fuel pump
My car won't turn over. When I turn the ignition on I don't hear the fuel injection pump. When it was running it sounded like it was missing a few cylinders. Suggestions?
Old Feb 26, 2013 | 02:36 PM
nickgost's Avatar
nickgost
What year is the car? Could be VATS. Is the security light doing anything when you turn the key?
Old Feb 26, 2013 | 02:37 PM
John A. Marker's Avatar
John A. Marker
First check your schrader valve and see if you have fuel pressure. Do you have a fuel pressure gauge? If so, then put it on the valve and check to see what your pressure is. I am assuming you have a 88. Pressure should be up around 36-42 pounds I believe.
Then check to see if you have spark.
Old Feb 26, 2013 | 02:38 PM
leesvet's Avatar
leesvet
what do you mean exactly?
it will not start? Does not engage the starter? or does not do ANYTHING when the key is turned to start? engine rotates but does not fire?
or it will not stay running?
big difference in no-start problems and running with multiple misfires.
More and specific info is needed.
Have you done the basic test?
spark
fuel pressure
injector
fuses
clean all battery connections as well as harness grounds
Old Feb 26, 2013 | 04:16 PM
vet1988's Avatar
vet1988
Cruising
The car is a 1988 35th anniversary
Old Feb 26, 2013 | 04:17 PM
vet1988's Avatar
vet1988
Cruising
It cranks over but it doesn't start
Old Feb 26, 2013 | 04:24 PM
383vett's Avatar
383vett
Any fuel in the tank?
Old Feb 26, 2013 | 04:35 PM
vet1988's Avatar
vet1988
Cruising
I checked the battery connections, and the FP fuse.
Old Feb 26, 2013 | 04:38 PM
vet1988's Avatar
vet1988
Cruising
Yes there is fuel in the tank
Old Feb 26, 2013 | 07:34 PM
leesvet's Avatar
leesvet
Push in the schrader valve....you should get a face full of gas. If NOT, then trace the missing voltage to the fuel pump. My first stop would be the fuel pump relay.
The C4 has a built in backup for that....if the relay fails, you can grind on the starter longer and as soon as that makes 4 psi oil pressure it WILL energize the fuel pump.
Try cranking non-stop for as much as 4-5 seconds...that should be long enough to generate oil pressure.
if no go...then start testing for a dead pump.
Somewhere in all this, verify spark with a spark tester or simply lay a plug on the engine and crank it and watch.
Old Feb 26, 2013 | 10:38 PM
vetteoz's Avatar
vetteoz
You know that for sure or are going by the gauge?
Originally Posted by nickgost
Could be VATS.
Unlikely if it is cranking over
Old Feb 27, 2013 | 12:06 AM
84VetteMan205hp's Avatar
84VetteMan205hp
Old Feb 27, 2013 | 08:18 AM
vet1988's Avatar
vet1988
Cruising
I will check the tank. I was going by the gauge.
Old Feb 27, 2013 | 08:49 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Is there 12v+ on both sides of fuel pump fuse, when ignition is switched to "RUN" ?
Old Feb 27, 2013 | 11:09 PM
vette 15x's Avatar
vette 15x
Default nostart
LEESVET is correct in his diagnosis,when get checking the pump and you will.It is real easy to remove and check,and you can check for fuel at same time.john
Old Apr 13, 2013 | 10:22 AM
vet1988's Avatar
vet1988
Cruising
I checked and the fuel was bad. I cleaned it out and put c-foam and new gas, but it won't start. It did get it to start when I removed the shraeder and sprayed starting fuid, but it didn't last long.
How do I get to the pump? Can anyone send me photos. This is for the '88.
Old Apr 13, 2013 | 03:16 PM
84VetteMan205hp
BAMMM!!! http://forums.corvetteforum.com/c4-t...h-article.html
To fuel pump
Old Apr 14, 2013 | 09:06 AM
vet1988's Avatar
vet1988
Cruising
You are the best! Thank you.
Old Apr 14, 2013 | 03:29 PM
C4in mesa's Avatar
C4in mesa
I hope so right !
Old Apr 16, 2013 | 03:31 PM
vet1988's Avatar
vet1988
Cruising
Changed the fuel pump relay. Still tries to start but don't hear the hum of the pump. Will do thast next unless someone has another suggestion.
