Walbro 400LPH
Old Mar 5, 2013 | 08:23 PM
666Vette91's Avatar
666Vette91
Default Walbro 400LPH
Anyone in the forum install a Walbro 400 in their 90/91 corvette?
Old Mar 5, 2013 | 10:17 PM
bjankuski's Avatar
bjankuski
That is a large pump, what is your goal.
Old Mar 6, 2013 | 12:54 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
A big pump?
Old Mar 11, 2013 | 12:07 AM
666Vette91's Avatar
666Vette91
Thank you for the questions, goal is to be around 600hp to the rear. first dyno pulls are at 524hp and 550 tq at the rear @5300rpm with the current 255 fuel pump. Starving for fuel so I am having bigger rails made with 8an fittings to the pump. Would like to know if anyone has used this particular Walbro 400 fuel pump. I was considering using the 340 stealth, but it would be running at the max.
Old Mar 12, 2013 | 06:53 PM
1985 Corvette's Avatar
1985 Corvette
I'd like to hear more about this build. Just me throwing spaghetti at the wall but have you considered duel Walboros? I guess depending on how much the 400 cost. What kind of build you got?
Old Mar 12, 2013 | 08:36 PM
666Vette91's Avatar
666Vette91
Yes, was considering two pumps however it looks like the tank will be modified to put in a A1000 efi pump (aeromotive)(over kill,yes) AN8 lines, regulator and bigger rails. Gil Navarez is my tuner @ Shelby American in Vegas. The ingredients are as follows...
383 4 bolt main Block bored to .30 over, decked, line honed
Eagle stroker crank Forged balanced (from HBR)
Eagle H rods Forged
JE Pistons Forged, weighted balanced
AFR 227 (1067) heads 75cc combustion chambers
Harland 1.6 rocker arms .50 off set w/girdle
Lunati Solid lifters
Lunati solid lifter cam 50121LUN - lift .600 in .618 ex
duration 308in/318ex lobe sep 106
Accel/Lingenfelter Super Ram ported/polished to match AFR Heads
Accel 1000 cfm throttle body
42lb green top fuel injectors - each flow checked
Methanol injection Snow Performance
P600 Procharger 5lb boost w/innercooler
MSD Ignition
Still would like to know if anyone has had a 400 Walbro pump put in their 90/91 vette though.
To Walbro 400LPH
