lcd dahs ground location
My dash you can see the numbers and lines, but very light and some time is compleately off.
also the display some times show one section and the other not. but is not like the part is damege because some time you can see that very same section light up in diferent ocacion. and the one that was working this time is off.
http://home.earthlink.net/~cliff_har...s/grounds.html
lear master . the force is strong on you
look like the ground never been there since I got the car...... 3 month ago I buy a good used lcd dash on ebay I install and work fine at firt. since the original one was totaly fried.
but now I have this issue. very low light. the lcd marks some times show parts some times show other parts.
I think is not a ground problem. also dont know if this is important, but the cortesy light on the food area stop working
it say can be a bad ground. but I allready checke the grounds and look ok.
so. it also say that son soldiers maybe loose. so i will have to open the dash. to check for loose solder.
I will repord back my finding
I think the problem are the cristals. is a black ink in some of the part of the cristals, and some of the case.
look like the liquid inside the cirstal is coming out.
I clean the cristal and reasembly the unit. and is not good.
I have some pictures and video to show
here you can see, the area where the most commun problem happed. and look ok.
[IMG]
[/IMG]here is the back part. also look good
[IMG]
[/IMG]here you can see the cotton is dirty after cleaning the cristal with some kind of ink
[IMG]
[/IMG]here you can see at the bottom of the case a bright area. like wet look. that is also the ink on the case
[IMG]
[/IMG]my hand dirty from that very same ink
[IMG]
[/IMG]the cristal contact they all look in a very good condition
[IMG]
[/IMG]
BTW this is an 84 digital dash,you can see a different style in graphics
[IMG]
[/IMG]
