90 Automatic won't turn over after setting TV
Old Mar 15, 2013 | 09:07 PM
KentsOkay's Avatar
KentsOkay
Default 90 Automatic won't turn over after setting TV
My automatic tranny was all acting up, so I reset the TV, as described in the Hane's manual (push tv to rear while depressing adjuster button, release button, open throttle) and now my car will not turn over, and it will not accept a jump. Not a sound is made when the key is turned. I set the TV with the vehicle in park. I attempted starts in P, N, and D+.
Sorry to be a noob, but hey, gotta start somewhere!
Old Mar 15, 2013 | 09:20 PM
KentsOkay's Avatar
KentsOkay
It is worth mentioning earlier this week I incorrectly adjusted the TV, it started, but wouldn't get out of first gear. Realizing my error I shut it down, it refused to start later that day when I tried to move it out of the way. Today before correctly adjusting it I tried to start it for ***** and giggles, it started. I shut it down, correctly adjusted the TV, now no start.
Old Mar 15, 2013 | 09:26 PM
bjankuski's Avatar
bjankuski
The no start has nothing to do with the tv adjustment, i would suppect your vats.
Old Mar 15, 2013 | 09:37 PM
KentsOkay's Avatar
KentsOkay
I did consider this, but no start wasn't an issue until I messed with the TV.
Time to go read all the VATS threads I suppose!
Old Mar 16, 2013 | 12:25 AM
Corvette40's Avatar
Corvette40
Might be that the original problem is the shifter linkage and your not getting into park. Put it in neutral and try to start, but if the TV cable is not adjusted properly the line pressure might not be high enough to shift gears.
Old Mar 16, 2013 | 12:34 AM
leesvet's Avatar
leesvet
trans safety switch as suggested OR VATS.
btw..
if you EVER want to do any work right...loose the hyenas manual and buy a real FSM. You get exactly what you pay for in this dept. For $19...not much.
To 90 Automatic won't turn over after setting TV
