Battery Cable End Replacment Options
Old Mar 20, 2013 | 01:50 PM
LTxDave's Avatar
LTxDave
Default Battery Cable End Replacment Options
The positive cable end on my 95 is in pretty bad shape. I know I can buy the replacement cables, but I'd like to just replace the end. The only thing I've found is at Orielly's and its a factory style connection with three short ends to splice into the original cables. Is there anything else out there? I'd rather find a terminal end and not add splices in the cables if possible.
Old Mar 20, 2013 | 02:34 PM
383vett's Avatar
383vett
If your cable has enough slack, you should be able to crimp on another terminal end. I have a hydraulic terminal end crimper, but Florida is about 3000 miles too far. An automotive electrical shop should be able to help you for a few bucks.
Old Mar 20, 2013 | 03:50 PM
WVZR-1's Avatar
WVZR-1
For many years I used something very similar to these to add auxiliary batteries to service vehicles and they worked very well. These are very similar to what you get if you purchase a cable off the shelf from a jobber anymore. I bought these a dozen at a time from an equipment supplier that is long out of business. Are these the same? Don't know but these could be crimped and soldered to your ends. I think Summit and Jegs might sell these also. I haven't looked.
** The 500337 part number works for many vendors and the terminals will do 0-2 gauge cable.
Halfway down in this PDF look at the 500724 - that's what these should look like assemblled!
http://www.americanautowire.com/cata...ableAccess.pdf
To Battery Cable End Replacment Options
