i was running a 770 double pumper and that was a ****** carb it was leaking gas and not performing properly, also it made my vette smell like a weed eater from the gassy exhaust. I just got rid of it and put a 650 single pumper 4 barrel on and its already gotten a lot better gas but i feel like it might have gotten slower.
my vette also has non stock headers or lifters and a TCI shift kit....
just curious to whoever else is out there running carbs
so is 650 CFM to high? its a heck of a lot better then the 770 was!
im running Edelbrock by the way! I can obtain a 600 CFM but what would the difference be?
Check your plugs to see if you still may be running rich. I have a 600 cfm 1405 edelbrock that I have leaned out as it was running a little rich and I seldom wind my engine over 4900. You should have received a tuning booklet with your carb if you bought it new. It will give you jetting and metering rod help for tuning your carb.
I run the Edelbrock 1406...... works great..
BTW: Ignore the 'home made' bracket... it's been changed.
so to all of you who do have carbs i did not put mine on i bought my vette like that. what are the perks or why did yall put carbs on your engine? and how the heck do you keep the intake from hitting the hood and cracking the paint directly on top of the contact point (((((
Depends on what intake you have.
A low profile intake with a drop base air cleaner will clear ;
in your case you may be in the market for one of these hi rise hoods? http://www.toledopro.com/vette-hoods.html
I have just recently purchased a Pro Systems Racing carb. Based off their tech, it's a large bore, smaller venturi design based off a 950 Holley HP carb. It's effectively an 838 cfm carb which I will be setting atop a Edelbrock RPM Air Gap dual plane manifold on top of a 383 stroker motor.
Dyno session will commence fairly soon, but expecting more than 525 hp, 500 tq. Videos to follow.
I don't get it. The C4 was a step forward to fuel injection yet i see people putting carbs on them.
Holley Carb = bucket with a hole
However if you feel the need to remove the fuel injection, along with easy start's and great fuel economy. When will someone do it properly and fit quad downdraft webber carbs. Then you can tune it properly and make serious horsepower without loosing too much in fuel economy.
