Holley EFI System?
Old Apr 8, 2013 | 06:19 PM
littleredcorvette88's Avatar
littleredcorvette88
Default Holley EFI System?
Anyone have any luck using one of the Holley EFI - self tuning systems? I'm currently have issues once again with some type of computer issue and and have been looking into this system to replace my stock computer (with newly reflashed chip). It may just be that I need to get my chip re flashed again cause something is off on the programing but if that idea fails I need to do something.
I would rather not spend the $$ at the shop to tell me they cant find the problem and instead replace the entire system. Any info would be great!....Its a high possibility I will go down this road if the computer issue doesn't get sorted out soon!
Old Apr 8, 2013 | 06:27 PM
LoneStarV's Avatar
LoneStarV
It would be cheaper to fix yours. What symptoms and codes do you have?
Old Apr 8, 2013 | 06:59 PM
vetteoz's Avatar
vetteoz
It may just be that I need to get my chip re flashed again cause something is off on the programing but if that idea fails I need to do something.:
Some more info on your setup and problems would help
Do you have a stock engine or a radical stroker motor???????
Old Apr 9, 2013 | 11:52 PM
littleredcorvette88
396ci forged
Comp cams hydraulic roller duration 242/248 lift 585/580
afr heads 195cc ported eliminator 75cc double valve springs, hardened retainers and locks, 1.6 comp cams rocker arms, 2.05" stainless intake valves 1.6" exhaust valves
Superram intake with lingenfelter 1000cfm throttle body
Hooker headers 1 3/4"
3" exhaust
36# injectors
Walboro 255 fuel pump
Old Apr 9, 2013 | 11:54 PM
littleredcorvette88
waiting to hear back from the shop....the power to the reader was shorting out somewhere so they couldn't pull the codes till the fixed the power issue....just my luck
Old Apr 10, 2013 | 02:40 AM
vetteoz's Avatar
vetteoz
Who is doing your tunes?
What is the LSA on the cam?
If those are the @ 50 duration numbers you are going to want a gun tuner
Even a "self tuning" system is going to have problems adjusting to that degree of valve overlap at idle
Old Apr 10, 2013 | 02:02 PM
383vett's Avatar
383vett
Those are some healthy duration numbers for a SuperRam. The SuperRam is made for mid to mid-high rpm torque. I ran mine to 6600 with my 406 and an extrude honed SuperRam. Your cam would be ideal for even higher rpms. You should still be able to get the thing to run though.
Old Apr 10, 2013 | 02:30 PM
TommyFox's Avatar
TommyFox
Who is doing your prom re-flash?
Old Apr 10, 2013 | 06:07 PM
littleredcorvette88
PCM for less made me a chip with all the new specs for the new motor....just not sure if the programming is completely correct
Old Apr 10, 2013 | 06:12 PM
vetteoz's Avatar
vetteoz
PCM for less made me a chip ....just not sure if the programming is completely correct
Are you sending them your datalogs so they can tweak the tune ?
Old Apr 12, 2013 | 05:09 PM
littleredcorvette88
just talked to the shop and they recommend sending my computer and chip back to pcm and have them run thru it again!! Not sure if I wanna do this again and wait a month and spend another $200...if I have to do this back and forth crap with pcmforless a few more times I could have bought an EFI system!
Anyone kow of any other good systems like the EFI?
Old Apr 12, 2013 | 08:51 PM
Rob31's Avatar
Rob31
Have you looked at the FAST EZ-EFI ? What distribrutor are you useing ?
Old Apr 13, 2013 | 09:02 AM
LD85's Avatar
LD85
I use the FAST XFI 2.0 , very easy to use, although I am still learning, but I agree that those duration's are tough to tune.
I had 238/242 and your overlap is worse than mine, you can tune the mid and upper RPM levels but idle will be very tough
Old Apr 13, 2013 | 10:15 AM
T. Wayne Nelson's Avatar
T. Wayne Nelson
I have a gen 7 by Accel. My cam is a 110 LSA, 238/142. I was easily able to smooth out the overlap. Car idles at 800 nicely...
Old Apr 13, 2013 | 11:20 AM
LD85's Avatar
LD85
It depends on what his "issues" are.
My 238/242 on 112/cl idled perfectly, never had an idle quality problem with the 165 ECM or the FAST XFI.
But for me, the fuel smell was the main issue, many people on the forum over time stated that they were able to tune big cams, later to find out that, fuel rich smell did not bother them, so this part of tuning, i.e. fuel smell is subjective.
If not for the fuel smell, I would have kept my 238/242 or even gone with a still bigger cam
If you want to know what your overlap is, use this easy calc
http://www.wallaceracing.com/overlap-calc.php
Old Apr 13, 2013 | 12:37 PM
383vett's Avatar
383vett
I have a Gen 6 by Accel. It's old, archaic, and you can't buy it anymore but it works for me.
Old Apr 13, 2013 | 01:23 PM
TommyFox's Avatar
TommyFox
You have to use a vacuum advance distributor or an ignition box.
To Holley EFI System?
Old Apr 13, 2013 | 02:20 PM
bjankuski's Avatar
bjankuski
Fyi the stock computer can be tuned to run your combination. Does the holley system use a wb O2 sensor or narrow band sensor? If it is a narrow band it will have issues with idle.
Old Apr 14, 2013 | 04:46 PM
littleredcorvette88
now looking into a dynamic efi system that would allow me to tune right at the dyno and no longer would need to go back and forth with my chip....anybody have any luck with dynamic efi?
Old Apr 15, 2013 | 05:14 PM
Rohn's Avatar
Rohn
dynamicefi is the way to go. hands down. I use it to tune my 84 vette. Yours will need port fuel mod. check it out on their site. It is MAP based.
