T56 swap??
Old Apr 8, 2013 | 11:03 PM
DDeRiso's Avatar
DDeRiso
Default T56 swap??
Hello I was wondering what would I need to do to get an lt1 t56 into my c4. It's an 84 (auto) I know I have to get the master cylinder, clutch, flywheel, bellhousing, new starter, modify the c beam, new pedal and change the brake pedal. Am I missing anything?? So here's my questions will a brake pedal assembly work for the clutch pedal or do I have to get a special clutch pedal assembly?? How or were should I get the modified c beam part ?? And anything else I need to do.
(Just making sure what I have to do to get this tranny in there before I start getting the parts)
Thanks for your time
Regards D
Old Apr 8, 2013 | 11:26 PM
vetteoz's Avatar
vetteoz
http://forums.corvetteforum.com/1551084186-post1.html
http://forums.corvetteforum.com/1550783015-post66.html
prostreetcustoms used to make a C4 T56 adapter.
How good are you with a welder? Plenty have made their own
Old Apr 8, 2013 | 11:31 PM
DDeRiso's Avatar
DDeRiso
Thanks for the info much appreciated
Now does anyone know about the clutch pedal
Old Apr 8, 2013 | 11:41 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Get the stock early C4 pedal assy from a salvage place. Same goes for the console bezel.
Old Apr 9, 2013 | 04:15 PM
ThatVguy's Avatar
ThatVguy
Did the bolt patterns change from the L98 SBC's to the LT1s? Or anything else that might not be applicable for doing this to the L98?
I have a 4L60E and have been contemplating this vs doing the ZF swap.
T56s happen to be in much greater supply than the ZF's.
Old Apr 9, 2013 | 04:19 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Shouldn't cause they were used on the Camaro LT1 motors. I'll be contemplating this swap myself.
Old Apr 9, 2013 | 04:27 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Bell housing bolt pattern is the same.
Old Apr 9, 2013 | 05:43 PM
DDeRiso's Avatar
DDeRiso
umm im not so good with a welder... lol could i have it made???
is there anywhere i could still buy it????
DHobbs's Avatar
DHobbs
Prostreetcustoms still makes them. Quality work too.
Old Apr 9, 2013 | 06:01 PM
vetteoz's Avatar
vetteoz
Originally Posted by ThatVguy
Did the bolt patterns change from the L98 SBC's to the LT1s?s.
Did you read the links I posted above ???
Old Apr 9, 2013 | 07:05 PM
DDeRiso's Avatar
DDeRiso
I did
Old Apr 9, 2013 | 07:07 PM
DDeRiso's Avatar
DDeRiso
For some reason I can't get on there website
How much do they charge???
Is there another way I could get in touch with them??
Regards D
Old Apr 10, 2013 | 12:25 AM
DanZ51's Avatar
DanZ51
You'll need to do some homework.
The T56 bellhousing will bolt up but the flywheel will not ('86 and up one piece rear main seal crank shaft flange). So that leaves either the aftermarket (expensive) flywheel or adapting the T56 to the common style bellhousing (which means you'll want a LS longer input shaft T56).
Study up.
Old Apr 10, 2013 | 10:45 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Study up.
He can get a later flywheel that works (like an F-bod LT1 flywheel) and have a machine shop modify the flange on the flywheel for the older 2 pc RMS. Also chop the counter weight at the same time.
I did this and the machine work was ~$80 Flywheel was ~$15 at a salvage yard. After that, parts/maintenance is easy. F-body clutch, PP, TOB, etc.
Old Apr 10, 2013 | 11:31 AM
ThatVguy's Avatar
ThatVguy
Is it worse that I say yes I did?
I re-read the first link however and then followed the link in that post, which of course, is a post that he himself is transitioning from an auto.
Thank you!
Old Apr 10, 2013 | 07:30 PM
DDeRiso's Avatar
DDeRiso
Study up.
Thanks for the info
And I'm trying to do my homework before I go and start buying thing
So I'll probably get the after market flywheel.
Do I still need the longer input shaft??
And I'm guessing but I'd be able to run the lt1 pressure plate and clutch correct ??
Regards D
Old Apr 10, 2013 | 07:39 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Thanks for the info
See^
To T56 swap??
Old Apr 10, 2013 | 08:07 PM
DDeRiso's Avatar
DDeRiso
See^
Alright cool thanks
D
Old Apr 10, 2013 | 08:25 PM
DDeRiso's Avatar
DDeRiso
Ohh and one more question
What kind of flywheel am I looking for??
Old Apr 10, 2013 | 08:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
No
Centerforce 700107 i believe is the pn for the flywheel.
DF kit...real happy with it.
well over 550chp holds just fine feels like a stock pedal no chatter issues
FW that adapts early crank to LTx style clutch
Do NOT use pressure plate regular bolts you want the McCleod ones Summit sells them.
Think its PN 1502 double check
Last time I looked ARP lists a PN for the LT1 but they are LSx bolts will not work
