383 temps
Old May 1, 2013 | 11:59 AM
94vette75's Avatar
94vette75
Default 383 temps
I have had my 383 running since March. The engine runs great. Projecting high 11's low 12's. Oil pressure 30 to 40 at idle,50 to 60 highway. Engine has roughly 600 miles. I have already changed oil at 400 miles, using 5w30 Mobile 1. Yesterday it was about88 degrees out and was caught up in traffic for a bit. I hit a peak coolant temp of 213 and oil temp crept up to 249 once I got moving again travelling at about70mph. I slowed down to 55mph and temps went down to 205 coolant and 228 oil. I have 3.54 gears with automatic. Is there something to worry about? Could it just be the engine needs to loosen up?. Oil pressure never changes from temp. Only first start up..then its like 70psi...any thoughts appreciated. Oh I also have long tubes...didn't know if there are heat transfer issues from headers...there is plenty of clearance from the filter though..also 94 LT1 is the engine...
Old May 1, 2013 | 01:16 PM
383vett's Avatar
383vett
Coolant temps look normal. The fans can be tuned to come on earlier. The oil temperature will hopefully go down soon. A new motor has more friction. Rings are bedding into the cylinder walls.
Old May 1, 2013 | 01:38 PM
bjankuski's Avatar
bjankuski
My fresh 406 with 250 miles on it runs oil temperatures 50 degrees hotter then the water. 170 water 220 oil. (No oil cooler)
Old May 1, 2013 | 01:49 PM
cv67's Avatar
cv67
St. Jude Donor '05
Run that thing up past 6000 hard a half dozen times or so it will loosen up.
So many baby a new motor its not needed now days.
Suggested long break in periods are for builders that have no faith in their work.
Bed the rings in first drive or so put 50 mi on and drop the hammer.
If something was going to break it would do it wether you babied it or not.
94vette75's Avatar
94vette75
ok.. I forgot to mention I have a csr electric water pump. I do have a mezier hd pump on the shelf. Do you think I should switch it?
Old May 1, 2013 | 01:53 PM
94vette75's Avatar
94vette75
I also have no oil cooler.
Old May 1, 2013 | 01:56 PM
94vette75's Avatar
94vette75
III
yea..lol I have only dropped the hammer twice so far up to about 80-90mph
Old May 1, 2013 | 02:08 PM
5abivt's Avatar
5abivt
This.
Temps sound normal. The cooling system is dealing with more heat and sitting still its going to struggle. Get the fans to turn on sooner it works well with an electric water pump. WHo did the tune?
Old May 1, 2013 | 02:22 PM
94vette75's Avatar
94vette75
Originally Posted by 5abivt
This.
madtuner did the tune. I believe he set them to 175 degrees.
Old May 1, 2013 | 02:35 PM
94vette75's Avatar
94vette75
Engine specs as follows. 11:1 comp...comp 467 cam...trickflow21* heads...scat forged pistons,rods,crank...58mm tb...long tubes...yank ss3600
..1.6 rr...6al digital msd.bearing clearance was a touch under .003 but right around there.. I assembled engine myself with balanced rotating assembly. Rings gaped for n2o
Old May 18, 2013 | 10:20 AM
Mike251959's Avatar
Mike251959
2nd Gear
Default 383 vette
Hi it looks just like mine with the 383 stoker but I have a heating problem riding down the road its running around 180 or 190 but when I get in heavy traffic just put a 3 row aluminum radiator any more ideas
Old May 19, 2013 | 11:02 PM
94vette75's Avatar
94vette75
I honestly think these cars don't have enough engine bay airflow to run any cooler
Old May 19, 2013 | 11:08 PM
cv67's Avatar
cv67
St. Jude Donor '05
nope sitting at idle the temp will always go up some normal
To 383 temps
