heater not working
Old May 5, 2013 | 12:14 PM
mgaunder24's Avatar
mgaunder24
3rd Gear
Default heater not working
I have a 1994 C4 and the heater doesn't work, is there a valve that could be stuck or does anyone know whats the problem and how to fix it? The air just doesn't get warm no matter how hot the engine gets. Any help will be appreciated.
Old Jun 24, 2013 | 04:25 AM
Mark Wade's Avatar
Mark Wade
good question my brother has the same problem, im not sure on valving but over the years i have always found little radiator up in the dash will be blocked ,major job to remove according to book good luck,let me know if you find something else were open to sugestions
Old Jun 24, 2013 | 08:24 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I don't know if it applies or not, but on my '94 to '96 Impalas/Caprices the heater is common to not blow hot air. On these it is easy to fix though.
The heater core fills up with some kind of sludge. Disconnect one end of the heater hoses and use a garden hose to flush/backflush the heater core. (you don't want to fully seal the garden hose to your heater hoses since the pressure will be too high up to about 45 psi. Just shoot water in the ends of the hoses is enough to cause a flow.) I have had three of those cars and all of them had that problem and a garden hose flush cured all of them.
Good luck.
Old Jun 24, 2013 | 02:08 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
One other thing to check: There is a restrictor in the inlet hose to the heater core. You can find it in the area just in front of the surge tank. It's posible for crap to clog up the hole in the restrictor, thereby blocking hot coolant from flowing to the core. You can easily check this by holding the out-flow hose from the heater core....it should be about the same temp as the inlet, when the enine is running.
Old Jun 24, 2013 | 02:18 PM
desertmike1's Avatar
desertmike1
Originally Posted by qcvette
i don't know if it applies or not, but on my '94 to '96 impalas/caprices the heater is common to not blow hot air. On these it is easy to fix though.
The heater core fills up with some kind of sludge. Disconnect one end of the heater hoses and use a garden hose to flush/backflush the heater core. (you don't want to fully seal the garden hose to your heater hoses since the pressure will be too high up to about 45 psi. Just shoot water in the ends of the hoses is enough to cause a flow.) i have had three of those cars and all of them had that problem and a garden hose flush cured all of them.
Good luck.
x2....
Old Jun 24, 2013 | 09:23 PM
Just BOB's Avatar
Just BOB
Good luck.
There's always lots of discussion on this problem in the forums in the fall/winter time in the lower 48. Clogged heater cores seem to be a common problem. As advised, flush it out, both directions, but be careful to not over pressure the core.
Old Jun 25, 2013 | 01:32 AM
Mark Wade's Avatar
Mark Wade
ITs winter down under here at the moment New Zealand snow bound you guys get your turn at Xmas,
Old Jun 25, 2013 | 03:07 PM
desertmike1
How funny! and I suppose we get youR A/C Questions in our Winter
Old Jun 25, 2013 | 06:39 PM
csthews's Avatar
csthews
Are you sure the heater core has not been bypassed? Leaking cores are common and the easiest thing to do is bypass them.
Old Jun 25, 2013 | 09:09 PM
pcolt94's Avatar
pcolt94
No heater control valve on a 94, coolant always flows.
After the engine comes up to temperature, grab the heater hoses and feel the temperatures. They should be as HOT, and as hot as the larger hoses to the radiator and surge tank. If the heater hoses are just warm the heater core is clogged.
It's easy to clean it out by disconnecting the two hoses and running water thru it in both directions. One hose goes to the surge tank and the other to the plastic fitting. Run a garden hose thru the core at LOW pressure in both directions.
On a personal note, when I got my car it took me about 12 times of back and forth to clean the core and for it to run clear (lots of crap came out). I found out at least for me I have to clean the core every one or 2 years for it to not clog again and to have heat when I need it. Every 2 years I do the coolant anyway so just do the core as a added bonus.
If the heater hoses are hot and water flow is not the problem, then the blend door will needed to be addressed which is another problem, investigation and repair.
Old Jun 26, 2013 | 04:11 AM
DanielRicany's Avatar
DanielRicany
It is possible that you also could have air inside the heater core, a neat little trick people do is open your radiator pressure cap, and jack the car up in the front so that the highest point in the system is the radiator neck. Turn your heat on, and run the car for 15-30 minutes. Some coolant may spill out but just top it off when you're done. This will allow the air to bleed out of the system.
To heater not working
