C4 rear coilover question
Old May 14, 2013 | 09:35 PM
Jimmypetersfit's Avatar
Jimmypetersfit
Navigator
Default C4 rear coilover question
Im swapping a normal rear end out of my 72 nova and putting in a c4 irs and im contemplating coilovers, but i wanted to know if the original shock mounts can carry the load of the car with the leaf removed...? Have many of you done this swap?
Any and all advice is welcomed!!
Thanks, Jimmy.
Old May 14, 2013 | 10:02 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
I highly recommend VanSteel's coilover lower mount bracket. It helps spread the load.
Old May 14, 2013 | 10:30 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Yes. And I've done the swap to my 89. My 90 has coil-overs also
Old May 14, 2013 | 11:00 PM
MarkBychowski's Avatar
MarkBychowski
I've been running coilovers for a couple years (van steel) and they hold up great. There are several others on the forum as well.
The only thing you'll want to check since it's a custom setup on your car is to make sure your bump stops bottom out before the shocks do. If you bottom out the shock on a huge bump, I could see that breaking the ear off.
Old May 14, 2013 | 11:15 PM
shakedown067
The nova is also packing more weight, so the regular shock stud probably wouldn't hold up well at all. I've never heard of a knuckle failing with coilovers...but I've seen plenty of photos of bent lower shock mounts.
Old May 15, 2013 | 11:13 AM
WVZR-1's Avatar
WVZR-1
Really?
OP - What do you actually weigh? A '72 A/C, 350TH and pretty well optioned would be 3250+ maybe but you mention modified so the addition of the C4 IRS is maybe a little less but close and who knows what ever else you've removed. You've many options for your C4 IRS mounting and I've seen A-bodied cars with the C4 IRS so I don't see any reason NOT to consider it. I believe you shouldn't have to search to far to find a half-dozen or so examples of similar swaps on the Nova sites.
The lower mount when you deal with a modified chassis is pretty much wide open to change. It sounds like an interesting packages. I wouldn't be easily discouraged if it was what you really wanted.
Old May 15, 2013 | 08:41 PM
Jimmypetersfit
Navigator
Hey guys, thanks for the info! I appreciate your input!
Jimmy
Old May 15, 2013 | 09:51 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I needed to move the coil-overs inboard, so I made some U shaped mounts from 3/16" steel.
To C4 rear coilover question
