Door Removal?
Old Jun 22, 2002 | 04:06 PM
IcemanZ06's Avatar
IcemanZ06
Default Door Removal?
Anyone know how to remove the passenger side door panel on a 94 corvette? It seems to be loose and I need to pull it anyways to adjust the passenger side window alignment. Any special tools needed and what should I watch out for.
Damn I really should invest in a shop manual
Old Jun 22, 2002 | 10:07 PM
IcemanZ06's Avatar
IcemanZ06
Default Re: Door Removal? (IcemanZ06)
anyone?
Old Jun 22, 2002 | 11:00 PM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
I can explain how to remove a panel for an 86, but I believe that the 94 is different.....
If you want, I can E mail you the directions from my repair manual.....
Let me know.....
Old Jun 22, 2002 | 11:52 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: Door Removal? (Husker Vette)
I think the 94 is different than the 92 but....
On mine the "tricky" screws were behind the slide lock, under the courtesy light lense and behind the power window switch. Another one that is easy to miss is behind the side door handle...
[Modified by Blue 92, 10:53 PM 6/22/2002]
To Door Removal?
