Oil Weight
Old May 17, 2013 | 03:22 PM
bobmac6's Avatar
bobmac6
Cruising
Default Oil Weight
I may have put 5w20 into my 1994 LT1...Do I need to get it out and put in the 5w30 its supposed to use????
Old May 17, 2013 | 08:05 PM
eatmydst1234's Avatar
eatmydst1234
You will probably be fine, just keep an eye on oil pressure. if it gets lower than normal you may want to.
Old May 17, 2013 | 09:22 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Even though 5w-20 isn't the correct spec, it is not going to ruin your engine.
I wouldn't use it all the time or long term, but its not an emergency that you get it out either.
Old May 17, 2013 | 09:25 PM
Benny42's Avatar
Benny42
After lots of reading on a motor oil forum, i run it in my '86L. No problems in 2 years and
lots of 1/8 mile passes.
Old May 18, 2013 | 07:37 AM
WW7's Avatar
WW7
I agree it won't ruin your engine, but since we are going into summer months I would change it to the right oil. In winter months I would say let it stay in....WW
Old May 18, 2013 | 08:19 AM
bobmac6's Avatar
bobmac6
Cruising
Default Thanks all
Thans all....
Old Jul 22, 2021 | 11:15 PM
douglasjre's Avatar
douglasjre
What are your cold pressures at idle and high revs and your hot pressures at idle and high revs
Old Jul 22, 2021 | 11:26 PM
aklim's Avatar
aklim
Last posted in way back in May of 2013 so my money is on the oil being changed and the incident forgotten. 05-18-2013, 07:19 AM
To Oil Weight
