Water Pump Install
Old Jun 22, 2002 | 10:57 PM
STL94LT1's Avatar
STL94LT1
Default Water Pump Install
I am going to change the water pump on my 94 next weekend. Does anyone have any tips or shortcuts? Should I use the 180* thermostat or change to the 160*?
MP
Old Jun 22, 2002 | 11:03 PM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
Default Re: Water Pump Install (STL94LT1)
Cover your Opti spark, or else you will probably be kicking out some major bucks for that also......
Here is a thread on a Thermostat question that I had earlier today.... Hope it helps....
T Stat Question
Old Jun 22, 2002 | 11:25 PM
GS Ragtop's Avatar
GS Ragtop
From: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
I changed mine out a couple of weeks ago. Tedious job, but not difficult. If you drain the radiator and pop out the knock sensors, there's very little anti-freeze left in the system to drench the Opti-Park.
Hardest part for me was standing on my head to clean off the old gasket that was cemented to the block. :cuss
Drop me a line if you have any problems. :cheers:
Brad
To Water Pump Install
