Car shuts off while driving
Old May 20, 2013 | 09:47 AM
LD85's Avatar
LD85
Default Car shuts off while driving
I was driving Friday and the car shut off, the dash and engine went totally dead, no lights, no dash, no ignition,
So I got out and opened the hood and then after @ 1-2 minutes, the power came back on, so I started it up and drove another 1/2 mile and it shut off again, so I coasted 100 yards and the car came back on and then stalled again and came back on as I was pulling into my neighborhood.
OK, where do I start, my guess is the the fusible links at the starter and or relays?
Old May 20, 2013 | 09:55 AM
John A. Marker's Avatar
John A. Marker
Check the red wire that plugs into the distributor. IF the clip is broken, it will sometimes slip off enough to cut off all electrical power to the distributor and will shut you down.
If it was a fusible link, the link (wire) would have burned thru and you would not start up...there would never be power thru the wire. You would have to replace the wire to get power again.
Old May 20, 2013 | 10:09 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I don't think it's the pink wire to the distributor because:
Originally Posted by LD85
I was driving Friday and the car shut off, the dash and engine went totally dead, no lights, no dash, no ignition?
I'd grab a test light and jack and drive back and forth in front of my house until it died...then start looking for power from the starter, moving toward the fuse box. I tend to agree with John that if it were a fusible link it would be 10-7 all the time. Not on/off.
Old May 20, 2013 | 10:38 AM
LD85's Avatar
LD85
Thanks guys, this is crazy, and scary, I had just gotten off the interstate when it happened.
Old May 20, 2013 | 12:23 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Never hurts to double check those battery cables and connections especially for a complete shut down like you are describing.
Old May 20, 2013 | 02:07 PM
rube1975's Avatar
rube1975
Old May 20, 2013 | 03:47 PM
Corvette Chris's Avatar
Corvette Chris
That's where I'd be starting..
Old May 20, 2013 | 04:10 PM
LD85's Avatar
LD85
I'll put it on the ramps and check the starter wiring first.
I have been wanting to buy new fusible links for quite some time because they are 28 years old.
Old May 20, 2013 | 04:16 PM
JackDidley's Avatar
JackDidley
Load test the battery. Bad battery can do some strange stuff.
Old May 20, 2013 | 08:46 PM
ch@0s's Avatar
ch@0s
I agree.. it sounds like battery/cables alternator or ground problem.It's probably something simple.
Old May 28, 2013 | 06:42 PM
LD85's Avatar
LD85
Yes, you guys were correct, it was loose battery cable nut on the starter, regardless of what I think I did, the nut was loose and I can wiggle it and kill power or get power.
Its great that its an easy fix, but ,,I fear that I must be losing my MoJo
Old May 28, 2013 | 06:52 PM
ch@0s's Avatar
ch@0s
It's normal when you do a big job your bound to forget something .. no one is perfect.
Old May 28, 2013 | 07:26 PM
LD85's Avatar
LD85
Well, it was not a nut, it was the #16 fusible link that is creating a short at the base of the link, I need to replace the one that reads 16 and has two red wires coming into it.
Any idea what slow blow maxi fuse amp to use? I'll start googling
Old May 28, 2013 | 07:48 PM
ch@0s's Avatar
ch@0s
You should be able to pick up another fusible link at any parts store.
Old May 28, 2013 | 08:28 PM
LD85's Avatar
LD85
cool, I called autozone and they have some 14 gauge links
Its the middle wire, it is nearly broken off at the point it joins the black connector, maybe only 2-3 strands connected
Old Jun 1, 2013 | 03:00 PM
LD85's Avatar
LD85
Its a wrap, all projects are done, and this problem is solved
I took the two wire fusible that went bad and stripped the two red wires back, and then put a length of 14 gauge fusible link onto the two red wires and used a metal C clip to crimp all 3 wires together, then wrapped it in friction tape.
I took all 3 ends that connect to the starter, and stripped them back and put them into a new ring connector and it's all good
Basically, it is redone exactly as it was originally except for the C-clip
If anyone wants a length or two of the 14 guage fusible link let me know, I bought a roll for $7.99 at NAPA
Baby doll is back on the road ready for tune tweaking
Old Jun 2, 2013 | 01:41 PM
ch@0s's Avatar
ch@0s
I'm waiting for the burnout video
Old Jun 2, 2013 | 04:17 PM
LD85's Avatar
LD85
As soon as its tuned its gonna scream, the 114 LS really stretches the curve, and 2nd and 3rd seem to last a long way but I can tell that its a little lean at tip in then it goes rich
I'll drive it to let the Adaptive Learning in the FAST XFI to adjust, then zero in on the tune.
To Car shuts off while driving
