Front Spring Removal
Old May 21, 2013 | 11:22 PM
cumbercr's Avatar
cumbercr
Default Front Spring Removal
I'm replacing bushings, ball joints and tie rods. I thought I would also install a lowering kit. But I'm wondering how to remove the spring without injuring myself. How to reinstall would be helpful too.
Old May 21, 2013 | 11:32 PM
don hall's Avatar
don hall
The author didn't care to use paragraphs...... you may get a headache:
https://www.corvetteforum.com/articl...ng-Removal.php
Old May 22, 2013 | 12:41 AM
mcm95403's Avatar
mcm95403
You'll already have the arms off, so you're only a few bolts away at that point. As long as you have the front end up high enough - a foot and a half or so - you can carefully jack up one side a little if you need to and then slide the spring out the high side.
Old May 22, 2013 | 12:48 AM
383vett's Avatar
383vett
If you already have the control arms off, remove the 2 bolts on each side holding the brackets and remove the spring. Some of the nuts in the engine compartment may be challenging to hold, but you can do it.
Old May 22, 2013 | 12:49 AM
vetteoz's Avatar
vetteoz
http://webpages.charter.net/khasting.../lowering.html
http://www.digitalcorvettes.com/foru...ad.php?t=79763
http://forums.corvetteforum.com/c4-t...ing-wedge.html
Old May 22, 2013 | 08:42 AM
cumbercr's Avatar
cumbercr
Thanks guys. This is exactly what I needed.
To Front Spring Removal
