Hi Voltage problem
Old May 25, 2013 | 07:25 PM
whmartin98's Avatar
whmartin98
Cruising
Default Hi Voltage problem
I have and 85 corvette and I am getting a high voltage reading in the DIC. The reading is 18.2, the battery is good, I replaced the starter not long ago, and today replaced the alternator. Still getting 18.2 reading any suggestions. Tks Wayne
Old May 25, 2013 | 07:26 PM
desertmike1's Avatar
desertmike1
Verify with a meter..
Old May 25, 2013 | 07:57 PM
whmartin98's Avatar
whmartin98
Cruising
will do thanks for the thought, Wayne
Old May 28, 2013 | 10:36 AM
whmartin98's Avatar
whmartin98
Cruising
checked with meter with engine not running found 12 volts, check with engine running found apprx 14.5, appears to me in the cluster. Does the ECM have anthing with this high voltage reading, maybe the ECM needs to be changed?? Let me know your thoughts, Tks Wayne
To Hi Voltage problem
