4+3 programming questions
Old Jun 16, 2013 | 12:37 AM
leoman's Avatar
leoman
Default 4+3 programming questions
I have a $6e I'm currently running. It was for an automatic, and I have the 4+3 with the proverbial cheap Radio Shack paddle switch grounding the relay for fully manual OD. My questions are:
1. I've set the 'manual' switch bit. Are there other parameters I ought to be changing on a bin originally for an automatic?
2. Despite the rewiring for manual OD, I assume the ecm still thinks it's setting OD whenever conditions warrant it. Does the ecm alter fuel/timing when it thinks it's in OD? If so can it be prevented without disassembling/hacking/reassembling the code itself, and if not, can anyone give advice on where/how to make changes?
Old Jun 16, 2013 | 04:22 PM
JackDidley's Avatar
JackDidley
I cant see anything else in the 6e that would make a difference.
Old Jun 25, 2013 | 06:07 PM
MrWillys's Avatar
MrWillys
If you want to run $6E, the use APYP for a manual trans. Your od must be disabled as you probably already know.
To 4+3 programming questions
