Hello guys, I'm new to the whole vette scene.. Diesels are more my thing, so Ide just like to say that I'm glad to be a part of the community. Therefore, the reason I am posting today is because my new project a 1985 C4 TPI is not working with me. I bought it and drove it home about an hour away. It ran good, just needed some things so I thought. I installed an slp ram air, MA Modified MAF, New plugs, new wires, new distributor cap and when I went to start it up it will idle not perfectly smooth but not bad either, but the main issue is that there is no throttle response. As soon as you press the throttle it Boggs down and even stalls. It seems to me that the cylinders aren't firing properly even though I am positive that I have the firing order correct. Could it be a timing issue? Fuel pressure? I don't know and I need to get this car running! Thanks in advanced guys.
Vlad
Vlad
It sounds to me like you did something wrong or one of the products you just put on is no good. Did you move the distributor at all? Have you checked your timing? Are you sure you did not cross a wire or two. Are you sure the MAF is good and why did you change it to begin with?
I changed the maf being that it ran much better unplugged when I bought it. I didn't touch anything that shouldn't have been touched, I just can't wrap my head around why it is running like this. The firing order is correct I checked multiple times, the plugs are gapped .35 and I even bought another set of wires.. I really am out of ideas?
I could be wrong, but .35 doesn't sound right. Might want to check this.
Actually, being that I switched out the MAF.. Would disconnecting the battery to reset the ECM work? I'm unsure how these engines act, I just know that with my cummins and pstroke. Resetting the battery works for practically everything haha
Well I have it a shot with the paper clip, but since I don't have a service engine light on, all that came up was the overdrive logo that flashed once then three more times.. This car just doesn't seem to like me much
One last thing I tried before it got to dark was to start it up with the new maf unplugged. It idled pretty nice, but as soon as I gave it some throttle it bogged out.. So that means it has to be something with the maf? It may be faulty or could the connection be bad being that I don't think there are relays for the maf in an 85? Sorry to keep pressing the issue, I'm just disgusted by the fact my whole weekend has been shot trying to get this thing going.. I just wanna drive!
Thanks for all the input guys, I just checked the 3 wires in the cap and found that the bottom wierd shaped prong has no wire connected and a black wire is not connected to it.. The other two prongs are wired? And what is the best way to check for a vacuum leak? Thanks again y'all
Alright guys, update after I just put the floodlights away and awoke all my neighbors. The vette seems to be running much better, timed it and it has a rather snappy throttle.. I was unable to take it out for a test drive being that after all the mishaps I have bad with it I now have gas in my oil. However when I fired it up, it ran nice with a 55 rpm and accelerated nicely in nuetral however I have smoke coming from what seems to be the pass. Side and the exhaust fumes smell wicked rich. Could this just be carbon build up? A bad o2? Anything else, I would greatly appreciate input. Was thinking of sea foaming the engine to clean it out and see any leaks, good idea?
