Code 61? Secondary port throttle valve system
Old Jun 26, 2013 | 03:12 PM
68xlch's Avatar
68xlch
Cruising
Default Code 61? Secondary port throttle valve system
Been pulling out what's left of the hair on my head troubleshooting a stall/won't start scenerio. I've had the car run great for a few miles and die. Turns over but won't start. A few days later I go out there and it starts. Today I was ready to read the codes. Course it started. I raced it up a few times and the car died. Won't start. I am getting a code 61 from the ECM but for the life of me I can't find much on this nor can I find any vacuum mechanism on the passenger side?
Do the symptoms even match a code 61?
BTW I have a VATS bypass in it now so that shouldn't be the issue.
BTW 1993 Anniv Edition. 93k. Never seen a winter. Comes with lots of goodies like an anniv shirt, watch, poster, shop manual, orig invoice laminated, two orig owners manuals, car cover, Corsa stainless exhaust and zr1 wheels. 6 speed. Nice car but I need to get it running and sell it. Too many toys.
Last edited by 68xlch; Jun 26, 2013 at 03:23 PM. Reason: adding year make and model
Old Jun 26, 2013 | 03:16 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Year might be helpful
Old Jun 26, 2013 | 03:18 PM
AGENT 86's Avatar
AGENT 86
You must have been thinking the same thing as I was typing.
Old Jun 26, 2013 | 03:20 PM
68xlch's Avatar
68xlch
Cruising
Yep. Stupid mistake.
Old Jun 26, 2013 | 03:21 PM
AGENT 86's Avatar
AGENT 86
61 Pass-key – key #1 programming resistance out of range
Not familiar with VATS on your year, but have you tried another key or cleaned the one you have ?
Old Jun 26, 2013 | 03:30 PM
68xlch's Avatar
68xlch
Cruising
So I was looking at the zr1 codes. Off to a great start. Thanks for the correction.
I'll try cleaning the two I have but it doesn't make sense to me that it would be a VATS issue if I have the Eckler's VATS bypass unit installed. I did do it myself and it didn't change the symptoms.
Old Jun 26, 2013 | 03:33 PM
68xlch's Avatar
68xlch
Cruising
Okay just cleaned both keys. No go.
Old Jun 26, 2013 | 04:13 PM
Hooked on Vettes's Avatar
Hooked on Vettes
There is no ecm code 61.
The explaination for a CCM code 61 was posted.
That probably occured if you messed with the bypass and
tried to start the car.
That code would prevent the starter from engaging.
Have you checked fuel pressure?
Have you pulled the fuel pressure regulator vacumm hose
and verified there is no gas in the hose?
When cranking have you verified there is spark to the plugs
when it doesn't start?
Old Jun 26, 2013 | 04:33 PM
68xlch's Avatar
68xlch
Cruising
I jumped pins A & B. It did exactly what I expected. It blinked the 12's and then 61. A&B jumped should be reading ECM codes not CCM. CCM I would have been jumping A & H no?
The car started today (again) and ran for 10 mins. It does this almost every time I go out to try it a few days later. I'll check the fuel pressure but it's so sporadic it really doens't make much sense.
Old Jun 26, 2013 | 04:39 PM
Hooked on Vettes
Problem is for a 1993 lt1 vin P there is no ECM code 61.
You must be counting the pulses incorrectly.
If you were to short pin A to Pin G turn the ignition On
The codes will be displayed in the dash LCD.
Module 1 CCM
Module 4 ECM
Old Jun 26, 2013 | 05:04 PM
68xlch's Avatar
68xlch
Cruising
Trust me I've "counted" the pulses 3 times. Let me try A & G. That was my next thought. Thanks.
Old Jun 26, 2013 | 05:14 PM
68xlch's Avatar
68xlch
Cruising
so the connector on my car only has one row of female pins so I'm lost. To follow A&G connections A would be upper right and G would be the lower row left pin.
Old Jun 26, 2013 | 05:19 PM
Hooked on Vettes
Old Jun 27, 2013 | 06:35 AM
68xlch's Avatar
68xlch
Cruising
I do
Old Jun 27, 2013 | 06:38 AM
68xlch's Avatar
68xlch
Cruising
I don't think you are following what I am trying to explain. My connector only has one row of open female plugs. The bottom row is plugged up. So there is no way to jump A&G. I have 6 open pins on the top row only.
Old Jun 27, 2013 | 07:47 AM
Hooked on Vettes
3 possible explainations.
1) You have an aftermarket wiring harness.
2) Bubba has worked on the car
3) Some one has removed the factory OBD 1 cover plug and
reinstalled it so the lower row of pins are blocked.
My guess is number 3
Old Jun 27, 2013 | 08:50 AM
68xlch's Avatar
68xlch
Cruising
My guess is Bubba sold me the damn car.
That plug has been used by my mechanic before to read the diags and it worked fine. I don't know why anyone would take the original out and go through the pain of putting something in that was not original but who knows. Guess I need to get it towed to him.
Old Jun 27, 2013 | 10:23 AM
Hooked on Vettes
Can you post a picture of the connector?
On the back side of the connector are there any wires going
to any of the blocked off bottom row of pins?
If you look at the ECM located above the battery under the
hood does it look like this?
To Code 61? Secondary port throttle valve system
